Page 2 of 2
Re: Recommissioning a 480: 9. Final Bits
Posted: Wed Jun 01, 2022 5:47 pm
by davekit
I'll have a look at those when I've a bit more time, thanks. The supplier that listed the correct numbers, but unavailable....If you click on the number for more details, it says they are Chrysler Jeep parts! Likewise the later sensors. Strange!
Posted: Fri Jun 03, 2022 7:59 pm
by davekit
Now I've fried my brains getting through the information, I'm pretty certain that the car has the wrong sensors fitted. I believe the early cars had PTC sensors (290 ohms), and the later cars had NTC sensors (2500 ohms). Mine should have the PTC sensors, and I've yet to find any for Volvo. Thinking about it, I would suggest that any PTC sensor would be an improvement over NTC sensors, at least the curve would go the right way!
I've tried to find equivalent Renault sensors. Renault 21 looks the most likely, as they were introduced in 1986, so may well have started with PTC sensors. The Renault engine code is F3N for the injected 1721cc, and looks equivalent to Volvo B18E, although power output varies. Renault 19 was introduced in 1989, so likely had NTC sensors from the off, and other models don't seem to fit the bill for various reasons. Probably the 440s and 460s never had PTC sensors either as they were late to the party.
There are certainly sensors on ebay which are described as PTC, but I've yet to find Renault or any other make which might be suitable. I've sent off a few enquiries, but they have either come back negative or I'm still waiting. I can't be the only person that needs these, can I? I will have to get the old ones off the car and check characteristics and threads, to see if I can find a match.
Posted: Sun Jun 05, 2022 3:23 pm
1721cc was fitted to the super5, which potentially sits in the right era - 85-94.
Posted: Wed Jun 08, 2022 10:42 am
by davekit
I've tried to make sense of the some of the similar-sounding makes of electric equipment on our cars.
Bendix is an long-established American company who make electrical equipment for aeronautical and automotive applications as well as washing machines and other domestic appliances; the parent company is Honeywell. The ECU on my 480 is labelled Bendix.
Renix was a tie up between Renault and Bendix to make electrical components for cars. Sensors and other parts on my 480 are marked Renix.
Fenix is a name I can only find in the Haynes manual, in relation to the engine management system. Is this a typo?
I've removed the air & coolant temperature sensors from the car and the full characteristics are:
Air temp - Renix Made in France 88-235 1537-1 blue. 2900 ohm @ 18deg, falling to 1000 ohm @ 60deg, 20mm push fit.
Coolant temp - Renix Made in France 1430-1 024-90 brown. 3800 ohm @ 18deg, falling to 1000 ohm @ 60deg, 12x1.5mm thread.
Quite definitely, these are NTC items, though the starting resistances are a bit high according to Haynes (2500 ohm @ 20deg). I've not been able to relate the numbers to anything, least of all the Volvo part numbers. Nor can I find any PTC items for Volvo or Renault, or any way of cross referencing them to any other brand. PTC items should be about 290 ohm @ 20deg, rising to 390 ohm @ 80deg. I would hope that any PTC item would be an improvement. PTC air sensors are pretty non-existent, but coolant sensors are available, mostly for Citroen and Peugeot. Unfortunately these have 14x1.25mm threads or even NPT imperial threads!
My latest idea is to simply wire in 300 ohm resistors in place of the sensors. At least the resistance would be in the right area, though the temperature dependence is lost (but not going the wrong way!). Any comments on the advisability of this?
Posted: Wed Jun 08, 2022 11:05 am
I wouldn’t waste your time with substituting in resistors. The resistances of your sensors are so out of range that the ECU will ignore them and use default values— hence you’re rough running.
Have you tried calling a Renault dealer to ask if they have the part number I recommended in an earlier post? Sorry, I’m abroad at the moment or I would have done it myself.
Also, what is the part number of your ECU? We need to make 100% sure you are meant to have the early black bodied sensors.
Renix has an “R” to do with Renault and Bendix; no idea what the “F” stands for in Fenix but it’s not a typo, that is really what it is called! They were very interchangeable in the early years as it’s basically a Renault system. It eventually all got eaten up in to Siemens. Chronologically ECUs are named Renix, Fenix and then Siemens— our Turbo cousins went with a completely different Bosch system.
Posted: Thu Jun 09, 2022 4:40 pm
by davekit
Thanks again James. I called a Renault dealer with that part number, and it was NLA, so no joy again. I'll try Hella next. The 1721cc engine also went in the Renault 9/11, certainly in carb form (type F2N) and possibly in injected form (type F3N) too. It was a well used lump, if we could only cross reference all the part numbers, we might yet find our PTC sensors. I also looked at the other references you gave me which gave the Renault number and Hella number, but the translation from Russian(!) did not always read too well. Pity a Russian trying to find a sensor for a Renault 21, especially at the moment.
I assume the ECU is the box under the side panel in the righthand footwell. This is embossed 'Bendix' and has a small label with '90190' on it, and a larger label with 'Bendix Made in France' and 'S101290101E' under a barcode and '436507' on it. These are all visible with the box in situ, so I have not tried to remove it to see what may be on the other side. None of these numbers match what I assume is the ECU in the parts list (#1 p203), which for my chassis should be 9031281-0.
Maybe the 'F' in Fenix is for French?!?!?
Posted: Thu Jun 09, 2022 6:45 pm
My car has the same S101290101E ECU installed so I guess we can be sure that you do require black sensors.
What a shame someone has probably put your perfectly good sensors in the bin and put the blue ones in.
Posted: Thu Jun 09, 2022 10:34 pm
Not that it’s possible to get them, but it looks like the Renault part number for the black bodied intake air temperature sensor is 7700731057
Posted: Fri Dec 30, 2022 6:07 pm
Hey Dave,
I had a bit of trouble with my own car today and ended up taking out the engine coolant temperature sensor and boiling it in a pan of water and did indeed start at around 290 Ohms and increase with temperature. I have ran with a later sensor installed and it doesn't run right-- you loose the cold idle RPM increase and its rich as hell but that could be the ECU using "default values".
You however seem to have both the wrong coolant temperature sensor and the wrong inlet air temperature sensor. Is that still true?
I may be able to help you out with an air intake sensor, but not with a the coolant temperature sensor.
Posted: Sat Dec 31, 2022 11:44 am
by davekit
Hi James
I've not changed the sensors, so they are still NTC type. Since the middle of the year, I've not been in a position to do much to the car, as a series of health issues culminated in two operations in November. This has left me at something of a low ebb. I am hoping that David Walker can take the car in January for some tlc, and get it back to top condition, as I don't feel capable of doing it at present. It's too good a car to simply abandon.
The sensor issue may only be resolved by swapping in two PTC types and seeing what effect they have. Even then some other adjustments could be needed, eg the CO potentiometer. It is probably not a good idea to have one PTC and one NTC sensor, as that would likely only confuse the ECU. Maybe David has some PTC sensors which could be tried, even doing a temporary swap from another car? If running deteriorated, at least we could be sure that the NTC sensors were correct, and we could look elsewhere to improve running.
Hope you managed to resolve the problem with your car. ATB - Dave
Posted: Wed Feb 08, 2023 8:50 am
Hey Dave,
I think at least one good sensor would make your car run a lot better-- the sensors to not work together so there will be no confusion of the ECU (its not that clever!). I have a black intake temperature sensor that I could send to you, which is very easy to install-- just a bit of wiggling to get it in to the intake pipe. Then I would suggest unplugging the blue coolant temperature sensor and leaving the wire hanging-- again just a minute's work. You would then be running as my B18E is, which is basically running very nicely but difficult to start without the coolant. This may be a good start and easily reversible.
Posted: Sat Feb 11, 2023 11:29 am
by davekit
Hi James
Many thanks for the offer of the air sensor. I will PM you with my address.
We are slowly coming out of winter, and my health is improving, so I should be able do something to the car soon.
BTW - the coolant sensor is brown, not blue, so I don't know the significance of this.
Cheers - Dave
Posted: Sun Feb 12, 2023 6:14 pm
by davekit
Hi James
The PM I sent seems to be stuck in the Outbox at the moment. Maybe it only shows as Sent once you read it? Will keep checking it.
Meanwhile the car today developed a bad misfire. It starts easily and the tickover comes down as it warms up. While the engine is cold it even pulls fairly well - better than it had before, I thought. Once it gets warm (water and oil over 80C), as soon as there is any load on the engine, the misfire occurs. It really is quite violent! Tickover is still fine, and downhill is ok, but the only way to go uphill is to drop a gear and use fairly high revs. I don't know if it would improve with further driving, as I didn't want to risk it. Once the engine has cooled it behaves normally again. Any ideas gratefully received!
Thanks - Dave
Posted: Sun Feb 12, 2023 7:21 pm
by Alan 480
davekit wrote: ↑Sun Feb 12, 2023 6:14 pm
Hi James
Thanks - Dave
If you don't have the correct PTC /NTC sensors fitted then I reckon the poor ECU is getting it's knickers in a twist, at ambient then maybe the temperature settings are 'close enuf'? As it warms then it will attempt to 'lean out' the mixture and shift the timing etc or opposite as it has 'lost the plot'
if it actually runs 'OK' without any variable temperature input, I'd just use a 'fixed value' resistor, which you could get from Maplin, now defunct
or even a 'variable' resistor? I ran a montego with a similar 'hack' just tweaked the setting depending on the air temperature, although I think it was mostly for starting?
if there was a cat, it will possibly be 'toast'?
Posted: Mon Feb 13, 2023 1:41 pm
I think if the ECU doesn’t get the right signal, it just assumes a single safe value. The only two signals that it can’t compensate for are the crank sensor and map sensor.
Posted: Mon Feb 13, 2023 5:41 pm
by Alan 480
jifflemon wrote: ↑Mon Feb 13, 2023 1:41 pm
I'd agree if 'nowt' but if the resistances are 'about right' / 'within tolerance' then it would screw the ECU even further?
Posted: Tue Feb 14, 2023 11:12 am
by davekit
Hi James
I've tried twice to send you a PM, but they are still in the Outbox. I've just changed internet provider so I wonder if the problem is at my end. Or has anyone else noticed a problem sending a PM?
Also, I forgot to ask, how much do you want for the air temp sensor? Or are you happy with sale-or-return?
Thanks to everyone for replies and suggestions.
Cheers - Dave
