cranna21
Post by cranna21 » Tue Aug 13, 2019 8:18 am
Hi folks,
I've previously had a topic in this area of the forum, but never really went anywhere with it, not that I'm promising to be a model poster on this thread BUT! I thought I'd post some kinda timeline of my ownership of my 480!
SO, I bought the car late November 2013 at the age of 18, totally standard, used the car daily for just over a year racking up 15000 miles! loved every second of it, surprisingly good on fuel but realised I wanted to try to keep the miles off it a little bit and bought another car to use daily!
In early 2014 I got my first “real job” and so the modifying bug hit… a set of scabby Ronal Turbo’s and eventually some Spax lowering springs fitted the bill nicely! But I realised I wanted a little more.
In 2015 the car was off the road sitting, I was trying to save up funds to do things right and the car received a dodgy paint job and a few other things that ended up being rectified further down the line, but learning curve, you get what you pay for!
Early 2016 the 480 returned! A new set of “proper” Ronal Aero 16’s and a power flow exhaust went onto the car, much needed improvements as well as a set of Bilstein shocks and some other small items.
The winter of 2016 and early 2017 saw the major renovation take place, Decided it was time to just “do it” so the car was stripped back to a shell, all glass out, all underside components off, every perishable item, bush, bearing and fuel/brake hose was replaced, every bush was upgraded to poly and all underside components were blasted and powdercoated! To top it off a set of GAZ Gold coilovers were installed. After getting the rear arches replaced and the whole car painted I got it delivered back to the shed and in 10 days had it totally reassembled and MOT’d ready for a show I wanted to attend!
The winter of 2017 and early 2018 saw the next phase, I wanted more power. I had a turbo engine sitting in my parts hoard along with some rare forged pistons but wasn’t totally sold on the idea. So hatched a plan based on hopes and prayers that a 2.0 16v engine from a Clio Williams would fit, after buying an engine already stripped requiring a rebuild I then caught wind of a deal I couldn’t pass up on and purchased a complete rebuilt engine fitted with a ported and polished head, uprated cams and possibly higher compression pistons that was previously fitted to a mk1 Clio. Along with this I bought a set of Jenvey 45mm throttle bodies and all the necessary hardware and sensors, ECU and so on to ‘make it go really fast’ haha. I coupled the engine with a JC5 089 Clio 172 phase 1 gearbox and after some head scratching with wiring and so on and mapping we had 208 bhp and 230 nm at the flywheel! She screams, redline is at 7200rpm just however the higher you rev the harder it pulls and its something else for a little old Volvo with pop ups 😊 Also fitted was a complete Recaro interior!
10 Points for anyone who recognises a certain Scottish 480 enthusiast in this picture! 😉
That’s about it for the moment, since Autumn 2018 she’s been in storage, there have been a few issues arise and teething problems needing addressed since the engine conversion as to be expected so this year I’ve been trying to clear my feet a bit with other projects and do some saving to fund improvements and so on!
Will try update this! But no promises as I’m terrible at that haha!
'91 480 ES 2.0l 16v 'Williams' Conversion - 208bhp/230nm
'91 940 GL 2.0l Estate
'09 C30 2.0d R-Design
Post by MisterH » Tue Aug 13, 2019 10:19 am
WOW! I am not a fan of modded cars, but what you have done is nothing short of amazing! Do
You have any plans going forward? It would make a fantastic Q-Car if it looked original on the outside, could create some nice surprises with that!
Also, those rear lights look immaculate, have you done anything to them?
I should that 480 should have the power it always needed, imagine if things had been a little different...
Maybe paint it in Clio Williams colours, with the gold alloys...
Really well done, that is truly unique
New Tires
Fix Radio/Cassette
Bodywork
cranna21
Post by cranna21 » Tue Aug 13, 2019 10:30 am
Hi MisterH,
thanks! for the most part, the exterior will stay how it is long term! I do plan on maybe applying some castrol livery similar to found on Volvo 242 GT's just for a laugh for a year, but that won't be forever!
over winter she just needs some odds and ends tidied up, a new starter motor and some heat management in the engine bay, some better tyres won't go amiss also as well as some interior refinements and a new clutch, this one isn't quite up to the task! haha
as for the rear lights, i did have them lacquered at the time of the respray, however, the laquer was not thick enough so has flaked now, so a wee sand and re-laquer is in order :)
Post by MisterH » Tue Aug 13, 2019 11:25 am
Ok, but in the first picture of the car in factory spec, they looked like new, did you do anything to preserve them?
You may have seen my post a while back regarding what to do to protect the lights, and wax is what I currently use, although I keep an eye out for potentially more effective treatments
New Tires
Fix Radio/Cassette
Bodywork
cranna21
Post by cranna21 » Tue Aug 13, 2019 12:08 pm
That was how they came when I purchased the car!
I believe it was just a well polished and waxed example :)
Post by jifflemon » Tue Aug 13, 2019 2:55 pm
Has the ABS been removed? I'm presuming you've a friendly MOT tester?
Bloody love it though - All that space above the gearbox makes me think you need a clio maxi style airbox to take advantage of the low pressure air in the windscreen scuttle
cranna21
Post by cranna21 » Tue Aug 13, 2019 3:00 pm
Non-ABS 1991 car sir ;)
now with that you could be on to something.... i had thought of just using a cold air feed from the front end, i guess i would just require an airbox round the trumpets and maybe some altercations to ensure plenty cold air came into the skuttle...
mathrock
Post by mathrock » Tue Aug 13, 2019 5:08 pm
Love the build!
Post by jifflemon » Tue Aug 13, 2019 8:30 pm
The area at the base of the windscreen is “dead air” - low pressure, easy to be sucked. Fair better than a front feed which is forced dependant on vehicle speed, obstructions blah blah blah....
cranna21
Post by cranna21 » Tue Aug 13, 2019 9:01 pm
Yeah right enough! Definite food for thought haha
Post by Alan 480 » Wed Aug 14, 2019 11:29 am
Love the build!
and I can confirm the attention detail is pretty impressive having seen it in the metal . . .. .
which is why i always park well away from this one :wink:
cranna21
Post by cranna21 » Wed Aug 14, 2019 1:16 pm
Love the build!
haha! thank you sir, however your new toy has me pretty jealous!
cranna21
Post by cranna21 » Thu Oct 24, 2019 1:19 pm
A wee update on the 'Williams' 480!
Dug it out the garage at home the other week so that over winter I can set too with some repairs/improvements and tweaks to amend some teething issues that arose after the engine conversion!
It's sat in the garage for over 12 months so safe to say I'm looking forward to getting back into the guts of it for some improvements!
- Fraser
Post by jifflemon » Thu Oct 24, 2019 1:53 pm
Somebody pass the popcorn! :D
Going to be interesting watching this.
cranna21
Post by cranna21 » Thu Oct 24, 2019 1:59 pm
unfortunately most of the mechanical improvements will be reliability based not power based! BUT hoping to spend some time on making the engine bay itself a nicer tidier place to look at with moving some cabling and plumbing about!
cranna21
Post by cranna21 » Tue Oct 29, 2019 11:12 am
Not much of an update!
but heads off - now away to get a strip, clean skim and re-assembly with new seals before back on with an MLS headgasket!
Next job once my new drill bits get here, drill the head off of 90% of the torx sump bolts because some absolute chocolate decided they'd put the sump on with what seems like a 6ft bar because the bolts that are still left to do are all rounded after me trying and failing to remove them!
no room to get an extractor on, no room to weld nuts on, so I guess cobalt drill bits it is :kill:
cranna21
Post by cranna21 » Wed Oct 30, 2019 10:18 am
New oil pump arrived today! the new pump comes with an uprated governer spring to increase the oil pressure, at the moment as I have fitted a Mocal 13 row oil cooler rad out the front of the coolant rad the increased oil capacity had an adverse effect on oil pressure, the OEM gauge on idle reads just above the 'minimum good area' so this should pump pressure up nicely to facilitate the oil cooler!
next on the shopping list is all of the components required to do away with power-assisted brakes in favour of a twin-piston biased system for better adjustability. Coupled with this over winter I intend to convert the car to using Clio RS 172 sport front hubs fitted with 480 wheel flanges, this will allow me to do some correction to the steering geometry that came about with me lowering the car too much and as a happy side note will let me fit MUCH larger brakes! WIN WIN!
Post by jifflemon » Wed Oct 30, 2019 11:18 am
Just a thought on the Oil Cooler - Get a stat for it.
You can get them built into the take off (much neater) or a separate one that plumbs into the lines.
cranna21
Post by cranna21 » Wed Oct 30, 2019 11:46 am
99% sure I have one built into my take off plate! from memory anyway, would need to take it off and check
Post by Alan 480 » Wed Oct 30, 2019 12:41 pm
easy option is to ditch the pressure sensor / gauge option ????
or just wire it to the same wire as the 'voltage output' gauge? :wink:
the Nora one just sits at 100% all the time as sensor aint there!! (and no real intention of fitting it as it was always a source of worry on any previous cars)
