Having got to this point most of the rust found is light but best found now so it doesn’t get worse.
A few examples.
With a few exceptions.
The door handles and fuel cap will have to come off when she goes to the paintshop (but doesn’t affect what I’m doing at the moment) the rest can be masked off or is internal and is mostly wiring looms.dcwalker wrote:I don't know about no more dismantling "required" - it doesn't look as if there is anything left to dismantle!
My thought exactly if it wasn’t for the damage just below the light, will probably still leave it in and get it repaired around it.dcwalker wrote:I wouldn't risk damaging them trying to get them out. Just make sure they're well masked and protected and work around them.
What it looked like after wire brushing.dcwalker wrote:... clearly you have the traditional solid rear bumper bar![]()
To be honest I don’t know, I hope early next year. Plan at the moment is to put running gear back on once undersealing is completed now rust has been sorted and then refit interior.dcwalker wrote:When will it all be done and back together, do you think?
Thanks, not quite the quick "tidy up" it started out as.dragonflyjewels wrote:This is a truly impressive rebuild.....
Not sure the better half would appreciate more time in the garage right now.dragonflyjewels wrote:.....wanna do 4 more ?
Take it you are talking about the black FrisbeesAlan 480 wrote:mmmmm dust covers?
wot are they?
I had two wee bits of rusty metal attached (well four if you count the front wheels as well)![]()
rear covers made from galv ducting and front from the side panel from somat, plastic coated ally (the stuff with the fake leather effect) but keeps worst of c**p off
