the coke seems to shift the rusty crud from block etc, flush out a few times then with fresh and add your favourite 'anti-freeze', I guess in your case for corrosion reduction, not for frost?
for the leaky rear hatch seal, i took my seal off then turned it around so it ran with outer side now on inner side, this 'perked' it up a bit.
watch those cables for rear wipe/screen heater etc. mine were starting to break up and sometimes the wiper worked sometimes it didn't, (MoT fail in UK) Volvo decide to make them ALL black so 'interesting trying to figure out which was which, fortunatley there is a fair bit of extra cable so managed to solder back together and put soldered section up inside the roof area so allowing a new section to flex
