The 440 is due a service before winter but I haven’t serviced a diesel before, do I have to change the fuel filter? If so where is it located?
Ad
440 TD Servicing
- Big Brother
- Moderator
440 TD Servicing
2001 V70
- hjkort
only replace the glowplugs when needed..
glowplugs are expensive, only replace them if the car doesn't start easy when cold.
If replacing is needed, replace all four of them, they will last longer. (same goes for lamps)
If you don't know when the fuelfilter has been changed for the last time, change it to be sure. You could check the fuelfilter by placing a seethrough line filter.
- Big Brother
- Moderator
