440 TD Servicing
The Volvo you want to know something about isn't a 480, but you can't find the answer to your question anywhere... Well, what the heck, have a try here in this corner of Volvos friendliest community...
Big Brother
Moderator
440 TD Servicing
Post by Big Brother » Fri Sep 22, 2006 8:07 pm
The 440 is due a service before winter but I haven’t serviced a diesel before, do I have to change the fuel filter? If so where is it located?
Ad
2001 V70
lee
Post by lee » Mon Sep 25, 2006 1:11 pm
It is worth doing the inline diesel filter. Also the glow plugs
hmmmmmmmmmmmmmmm
hjkort
Post by hjkort » Mon Sep 25, 2006 1:23 pm
only replace the glowplugs when needed..
glowplugs are expensive, only replace them if the car doesn't start easy when cold.
If replacing is needed, replace all four of them, they will last longer. (same goes for lamps)
If you don't know when the fuelfilter has been changed for the last time, change it to be sure. You could check the fuelfilter by placing a seethrough line filter.
Big Brother
Moderator
Post by Big Brother » Thu Sep 28, 2006 6:55 pm
Cheers guys. Will get the oil and fuel filter done, the glow plugs look ok. Do diesels use a completely different type/grade of oil?
Ad
2001 V70
