ICV not moving by ECU
gsa60
Post by gsa60 » Sat Nov 08, 2025 11:15 am
Hi,
My ICV is not moving anymore...
I however have tried directly shorting the pins and it moves if I apply some voltage.
Also, while removing the icv, i tested manually opening it a bit in various angles. And this is the odd part: when opened too much
The ecu would not try to close it .. when i closed it manually too much... The ecu would not try to open it.
Maybe it's jus lt the common earth pin.. but IDK
So I am guessing there is some issue with the wiring.
Does any one know wich pins of the ecu, the 3-pin icv connects to? That way i can check for continuity.
Engine : 1991 B18FTM.
Other than that. If anyone has some more ideas, let me know.
Re: ICV not moving by ECU
Post by jamescarruthers » Mon Nov 10, 2025 12:05 pm
There are three connections. One is permanently powered, the other two are both earths that the ECU controls with a varying frequency. I am guessing one side does ‘close’ and the other ‘open’?
Nice fix: Maybe you have a broken wire on one of the earth/return wires that the ECU pulses to get the desired position? Ring out the three wires to the ECU plug?
Nasty fault: you’ve blown up the output on the ECU by probing. Hopefully not though.
The valve itself could be faulty of course. There is a mechanical limp mode which just has it sprung to a certain air hole size.
Post by jamescarruthers » Mon Nov 10, 2025 12:22 pm
Drop me a PM with your email and I can send you the Green Book for the Turbo engine which should have all the details in for troubleshooting and hopefully fixing.
gsa60
Post by gsa60 » Thu Dec 18, 2025 9:51 am
Thanks James!
Found the issue as a broken wire... It was a bit strange as it was jus near the suspension housing stuff where all the other wires are :/.
