Well I need some help with identifying what parts/bits are worth saving as I have bought a parts car as my turbo was involved in an accident. I will write it to my story when stuff is sorted out.
So the parts car is I belive an early 480 es but I can't check the vin, as it has been "stored for another car". It has no headrests in the back, large? wing mirror/s, unpainted bumpers and thin side mouldings, and black carpet with latex-ish under side. The engine is a 1.7 NA, with fenix? ecu, I belive that because of some GM stamping on the parts found in the engine bay. Need to compare if the chassis loom is the same as mine, but I could already spot a difference in the connectors on the block. It also has the no ac and bottom mount power steering pump.
I got it already half robbed, and the car was outside for 5 years, so the elements have done its toll on most of the parts. But the carpet although actually having a rat's nest inside looks undamaged.
