The joys of 480 ownership
GCooper
Post by GCooper » Sat Oct 15, 2022 1:26 pm
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
Re: The joys of 480 ownership
Post by jamescarruthers » Sat Oct 15, 2022 11:55 pm
Have you kept it in the sea since 29 October 2021?
GCooper
Post by GCooper » Sun Oct 16, 2022 9:47 am
I just went to a more thorough garage
'98 BMW Z3 (daily)
Post by jifflemon » Mon Oct 17, 2022 6:12 am
Doesn’t read that bad to me; pretty much standard fail items.
Rear brakes (just service them)
Rear inner sills (they all go there)
did it actually overheat? Or did they find the rot, knew it’d fail so invented a reason for not testing?
To me, it’s not a “thorough” garage, more one that hates older cars, as evidenced by the huge amount of advisories.
100
Post by 100 » Mon Oct 17, 2022 8:12 am
100% this, I went to one and they asked me whether I was going to scrap it following the MOT. They just didn't get it at all.
Post by WillC9303 » Mon Oct 17, 2022 9:32 am
I had the same issue as you a couple months back when I went to MOT mine.
Failed on a lot of stuff, and got advisories for stupid things like surface rust on the rear axle and ‘welding work’ that had been done to a good standard anyway.
Took it home, fixed only the rear brake issue and it passed at another garage with no advisories about 3 days later! You can read the history for yourself (L309SGO)
GCooper
Post by GCooper » Mon Oct 17, 2022 12:54 pm
A few weeks ago the coolant fan got stuck on so I disconnected it, I told them not to keep it on for too long because of this, so I guess they didn't bother
'98 BMW Z3 (daily)
Post by jamescarruthers » Mon Oct 17, 2022 1:11 pm
You couldn’t have turned up screaming “this is an old banger” any louder. No wonder they did all they could to get it off the road. No cooling fan is asking for a 480 to overheat when stationary and asking an MOT station, who I assume aren’t your friends, to go easy on its cooling system because the fan isn’t working as designed and is just starting you off on the wrong foot.
Post by dcwalker » Tue Oct 18, 2022 8:24 am
Sorry, but I couldn't agree more.
Our cars are, to many, just old cars. You have to overcome that perception from the start. So, when you take your car to MOT make sure it's clean inside and out and that every obvious fault you are aware of has been sorted. Otherwise, your car just screams "I am not cared for or looked after" and your average MOT tester will start from the negative position of expecting to fail it and then ensuring that is the outcome.
The moment you declared a cooling system problem which you had tackled just by disconnecting the fan, you sank your chances completely.
Leaving aside the MOT issue, these engines get very hot quite readily: don't ignore your cooling fan problem, get it sorted, or you'll be overheating with disastrous results.
GCooper
Post by GCooper » Thu Oct 27, 2022 2:58 pm
The good news is that the repairs are much cheaper than I had expected, so it will be back on the road soon
'98 BMW Z3 (daily)
Post by WillC9303 » Thu Oct 27, 2022 3:47 pm
great to hear!
Post by jamescarruthers » Thu Oct 27, 2022 7:05 pm
Excellent news! :hopping:
Post by dcwalker » Fri Oct 28, 2022 6:45 am
That's good to hear :D Hope you're back on the road again soon...
