The joys of 480 ownership
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Re: The joys of 480 ownership
Have you kept it in the sea since 29 October 2021?
I just went to a more thorough garage
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Doesn’t read that bad to me; pretty much standard fail items.
Rear brakes (just service them)
Rear inner sills (they all go there)
did it actually overheat? Or did they find the rot, knew it’d fail so invented a reason for not testing?
To me, it’s not a “thorough” garage, more one that hates older cars, as evidenced by the huge amount of advisories.
100% this, I went to one and they asked me whether I was going to scrap it following the MOT. They just didn't get it at all.jifflemon wrote: ↑Mon Oct 17, 2022 6:12 amDoesn’t read that bad to me; pretty much standard fail items.
- WillC9303
I had the same issue as you a couple months back when I went to MOT mine.
Failed on a lot of stuff, and got advisories for stupid things like surface rust on the rear axle and ‘welding work’ that had been done to a good standard anyway.
Took it home, fixed only the rear brake issue and it passed at another garage with no advisories about 3 days later! You can read the history for yourself (L309SGO)
A few weeks ago the coolant fan got stuck on so I disconnected it, I told them not to keep it on for too long because of this, so I guess they didn't botherjifflemon wrote: ↑Mon Oct 17, 2022 6:12 amDoesn’t read that bad to me; pretty much standard fail items.
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
You couldn’t have turned up screaming “this is an old banger” any louder. No wonder they did all they could to get it off the road. No cooling fan is asking for a 480 to overheat when stationary and asking an MOT station, who I assume aren’t your friends, to go easy on its cooling system because the fan isn’t working as designed and is just starting you off on the wrong foot.
Sorry, but I couldn't agree more.jamescarruthers wrote: ↑Mon Oct 17, 2022 1:11 pmYou couldn’t have turned up screaming “this is an old banger” any louder. No wonder they did all they could to get it off the road. No cooling fan is asking for a 480 to overheat when stationary and asking an MOT station, who I assume aren’t your friends, to go easy on its cooling system because the fan isn’t working as designed and is just starting you off on the wrong foot.
Our cars are, to many, just old cars. You have to overcome that perception from the start. So, when you take your car to MOT make sure it's clean inside and out and that every obvious fault you are aware of has been sorted. Otherwise, your car just screams "I am not cared for or looked after" and your average MOT tester will start from the negative position of expecting to fail it and then ensuring that is the outcome.
The moment you declared a cooling system problem which you had tackled just by disconnecting the fan, you sank your chances completely.
Leaving aside the MOT issue, these engines get very hot quite readily: don't ignore your cooling fan problem, get it sorted, or you'll be overheating with disastrous results.
The good news is that the repairs are much cheaper than I had expected, so it will be back on the road soon
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Excellent news!
That's good to hear Hope you're back on the road again soon...
