New Year, New 480!
Re: New Year, New 480!
Post by Martin Mc » Sat Jan 04, 2020 8:54 am
Fri Jan 03, 2020 5:43 pm
Ok, so lets bash them down one by one....
Martin Mc wrote:
Fri Jan 03, 2020 9:56 am
1) Running lumpy as the sea (I suspect it needs a good run)
Never forget MMM. That is, Motors Must Move. A good dose of usage, followed by a sympathetic service (Including things like Cap/Rotor/Fuel filter) will soon have it back on form!
2) Speedo, mileometer and info centre inoperative (cooeee Brinkie! Will be in touch if you are still able to help!)
Check the very obvious (fuse, Rheostat turned down) but I'm sure the lord of dashboards will be here shortly!
3) Damp as a swamp inside (will dry out in my garage for a few days_
Personally, rip the interior out - it'll dry a whole lot quicker as well as help trace where the water is getting in. It's also much easier to clean, and makes the car smell much better too!
4) No way of knowing how much fuel is on board - will have to wing it on the way home :0)
Always exciting is life in a 480! :rofl:
5) Headlamps pop up and down randomly and not in synchro - looks like Roger Moore's eyebrows on speed! - but at least it confirms the motors are ok :)
Out of synchro would suggest someones been knob winding and got bored! Like you say, at least it confirms you've got working motors. I use and advanced method of Brinkies previously fix - I run both simultaneously (rather than one at a time). The only drawback is that it means you only get a single cup of tea of course....
Martin Mc wrote:
Fri Jan 03, 2020 1:00 pm
6) Handbrake at 0% efficiency! Hence my concern about leaving it on deck, on a ferry, in the Irish Sea, secured only by reverse gear and steering lock :eek:
Pull it apart and reset it. My money says its only ever been adjusted "on the cable" and has gone over centre.
Looking forward to more updates!
Brilliant! Got her back home around 11pm last night - battery had gone flat whilst on the sea crossing, so it took ages to get her off the boat and back onto dry land. The run from Liverpool to Blackburn was interesting - Electrics on the dashboard sprang partially back to life; still no speedo or mileometer; throttle cable sticks I think so tending to over-rev at junction; gearbox got more and more notchy as it heated up; brakes are binding a bit I think, but overall it was fine.
Will give her a good clean this morning and lubricate some bits and bobs, check electrical connections etc.
The work of the moneypit begins!
Volvo 480 - There's NOTHING like it!
Previous 480 pedigree: 1992 ES (1.7 White) 1993 ES (2.0 Red) 1994 S (1.7 White) 1995 S (1.7 Black) #467 / 480 Celebration (flame red metallic) 1993 ES (2.0 Paris Blue)
Post by dragonflyjewels » Sat Jan 04, 2020 9:01 am
Well done Martin ! I'd been looking longingly at that one, entirely due to the red dipstick - it IS a 2 litre isn't it ? If so I can promise you a somewhat smokey exhaust with the need to keep a close eye on the oil level, but a whole lot of bottom end grunt. I've had mine since 2001 and will probably never sell it - couldn't bear to lose all that fun !
Hope you get it all sorted without too much pain and look forward to seeing you at a meet soon.
Lethal Lily - 1991 White Turbo with richmod
Sven - 1994 Dark Green GT
Evil Eva 1992 Paris Blue Turbo with Robou mod
Post by jifflemon » Sat Jan 04, 2020 4:49 pm
OK, so more good news(ish!).
Battery? Check charge rate - Covered it in a post in the how to's. Could just need a new battery.
Dashboard - broken cog - Again, there's a how to!
Gearbox? Change oil! (that service thing I mentioned!)
Brakes - Remove and grease the sliders! Probably just surface rust from standing around - remember, MMM!!!
Post by brinkie » Sat Jan 04, 2020 8:29 pm
Reporting for duty! :lol:
:rofl:
I would hazard a guess that the relay is sticking. Clean it, or put another in.
My experience is that the brake cilinders have gone bad (sticking), or someone has been adjusting the handbrake without proper knowledge of the system. It's best to take the brake cilinder apart and put new parts in if re-adjustment fails.
Post by Martin Mc » Sun Jan 05, 2020 12:04 pm
Roger Moore's Eyebrows on Speed
Well, I thought I'd cracked the problem this morning, when I noticed that the DRL were running with different brightness, suggesting a problem in that area. On inspection, there was indeed a problem on one side,with a defective DRL bulb. So I replaced the defective bulb,and now the DRL appear to function properly with headlamps up (i.e.dimmed to 5W).
Fired up the old girl to test the fix, but it is still doing the weird headlamps popping up and down thing, when the engine / ignition is on and headlamps turned off. You may be able to see what I mean via this link:
https://i.imgur.com/ExyAvrr.mp4
:lol:
Any ideas?
Post by Martin Mc » Sun Jan 05, 2020 3:43 pm
Couple more bits of info.
Car is idling a bit fast when warm, around 1100 rpm. Not sure why this might be, but it might just be lack of use..
Am missing slider knobs for the heating / vents on the dashboard (I'd normally replace these anyway as they are invariably grubby. Does anyone have any spares (£) or know where I might purloin a couple?
As you can see, a previous owner has added a voltmeter and oil pressure gauge :)
Other good news - both heated seats are toasty and working so at least I'll be able to enjoy the sensation of having wet my pants once the weather turns colder :)
Oh, and the diagram under the under-bonnet relay lid is missing (perhaps someone might have a spare or a photo which I could print and trim)?
the
I have a couple of spare relays (412653 oem) though untested - are these the same as for the pop-up headlamps? If so, perhaps I should try swapping them around? I'm not sure if there are any relays missing on the board. Anyone know what I should have in there?
Am booking the car in for the handbrake and MOT this week.. Will update as and when things develop.
JohnTurbo
Post by JohnTurbo » Sun Jan 05, 2020 4:22 pm
Blackburn huh?
Just up the road.
I am J8 M65.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
Post by jifflemon » Sun Jan 05, 2020 6:20 pm
Drop me your address - I've a couple that were 3d printed and finished off by hand, you can have them for nowt.
that sounds like the fella!
Post by Martin Mc » Mon Jan 06, 2020 5:21 pm
Ok, so she failed the MOT this afternoon... :( But the good news is that it wasn't on very much! :hopping:
It looks like it will be a case of new discs and pads at the front, and possibly a caliper at the rear, but that is pretty much it!!
Could be on the road by later this week :) Brill!
Watch this space!
Post by Alan 480 » Mon Jan 06, 2020 6:48 pm
Watch this space!
Good news (in way)
the caliper might actually be OK, I know that Jiffelemon did a 'how to' on teh re-build, I only went as far as removal of the main piston and cleaning the cr*p out of the internal screw thread /adjuster part, made one heck of a difference
PS you might be lucky and it just needs adjusted up (on caliper) to within a third of turn, tighten, spin wheel, repeat and back off a 'thochty' , assuming that the lever arms are touching the stops when the handbrake is OFF, and cables are free to allow the internal wires to return?
Post by Martin Mc » Mon Jan 06, 2020 7:11 pm
Blackburn huh?
Just up the road.
I am J8 M65.
That could be handy for a local mini-mini meet! Hopefully I'll be back on the road by the weekend, and a bit of a burn up the M65 would probably do the car a power of good :)
Post by dcwalker » Mon Jan 06, 2020 11:25 pm
Blackburn huh?
Just up the road.
I am J8 M65.
When you fancy going a bit further afield, you're always welcome across the Pennines...
Good news the the MOT - that all sounds easily sorted.
Current: 1994 480 GT, 1995 480 Celebration 467/480 (plus 2004 C70 Collection)
Previous: Celebration 346 (sold to Alan480), Celebration 269 (scrapped abandoned project), Celebration 73, 1992 ES, 1988 ES - and numerous other non-480 Volvos!
Post by MisterH » Tue Jan 07, 2020 9:00 pm
If the speedo connectors have been resoldered in the engine bay, check to see if it has been earthed to the body shell mistakenly. after a year of trying to fix it, cut one wire on my car and it burst into life :wall:
Current Jobs to do (30/12/19):
New Tires
Fix Radio/Cassette
Bodywork
Post by Martin Mc » Tue Jan 07, 2020 9:18 pm
Hello there,
That sounds like something to look into, when I get the car back from its MOT & repairs. I think I can find it, based on the info in the Haynes manual. Will report back what I find. :eek:
All the best!
Post by brinkie » Tue Jan 07, 2020 10:31 pm
Martin's car got the updated electrics (post-1991), they don't have the problems that occurred in the first three model years with shielded cable. I think soldering of the green and grey connectors will solve the speedometer problems. If not, we can search further :)
Post by Martin Mc » Wed Jan 08, 2020 11:57 am
Hello Robert, that sounds like the best idea. A quick update following the MOT though:
1) There appears to be the wrong caliper on one side at the rear, and this has been botched so that all fixings are either rounded out / off or not present :shock:
2) Whoever had the car last appears to have cut off one of the handbrake cables at the back (another bodge job) and left the other one as tight as a tyrannosaurus' testicle. Basically it means the entire braking set up at the back needs rebuilding (££ / time :cryhard: )
3) My local friendly garage, who have tended to all 6 of my 480 projects over the years (and so who I know always look after me) have agreed to do the rebuild out of hours as a favour / training opportunity for a new lad, which means I won't get the car back with its shiny new MOT till the end of next week (17th or 18th Jan) at the earliest.
All of this means I won't be able to get the instrument cluster off and over to you till probably early next month.
But the good news is, I should be able to use the car again (as a daily driver) in a couple of weeks! Woo hoo! :D
Watch this space!
All the best!
Post by brinkie » Wed Jan 08, 2020 1:22 pm
If you give me the mileage and if there is SRS (air bag) present or not, I could try and build a completely "new" one, send it to you and you will have absolutely no downtime. You can send the old unit back afterwards, there is no hurry.
(if I can find a speedometer in miles in one of the boxes in my loft that is!)
Post by brinkie » Thu Jan 09, 2020 8:45 am
Good news, I have found one! It's a good thing you've posted pictures of the instrument cluster here, I will build an exact copy this weekend.
Did you already source another popup headlight relay? I can put one in as well. (need any more parts btw? the box is quite big)
Post by Alan 480 » Thu Jan 09, 2020 12:38 pm
wot? 480 sized :wink:
Post by brinkie » Thu Jan 09, 2020 3:13 pm
:rofl: :rofl: :rofl:
