Moving this out of Spotted.
It looks great stuff.
If you were to dribble it over a crack in say a rear light cluster once its worked its way in and dried can the residual on the surface be cleaned/polished/scraped off easily leaving a flat smooth surface?
Captain Tolleys Creep and Cure
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Re: Captain Tolleys Creep and Cure
Check your PMs!
In theory yes.
They advise to wipe before it dries in.
I have used it on screen leaks.
I've bought a bottle of this and will be using it soon so I'll keep you updated.
I may be using it in conjunction with some other sealant but hopefully between the two it'll do the trick.
If I'm honest, I didn't want to use sealant and would have preferred a set of new seals to do the job properly, BUT, having looked closely at the existing cluster and how its been done, I don't think i could remove it without a high risk of damage. With the clusters as rare as hens teeth I'm going to have to go against my instincts and re-silicone. Hey ho...as long as it is dry that's the main thing.
Know what you mean my car is stripped down and will have an almost full re-spray when I’ve finished the other work but I have had to leave the rear lights in for fear of damage.PJP wrote: ↑Sun Oct 29, 2017 12:18 pmIf I'm honest, I didn't want to use sealant and would have preferred a set of new seals to do the job properly, BUT, having looked closely at the existing cluster and how its been done, I don't think i could remove it without a high risk of damage. With the clusters as rare as hens teeth I'm going to have to go against my instincts and re-silicone. Hey ho...as long as it is dry that's the main thing.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
I LOVE this! It drys to a thin quite stiff powdery residue, like very dilute, brittle PVA glue. On my white paint work it looks a bit like dried unbuffed wax when I miss a bit, by this time its pretty hard to shift- on paint I struggle to shift it with cutting compound, but I think it would sand quite nicely on the lights. I think its great for a quick repair on a back window, lamp seal etc when you dont have time to strip it down. I really recommend giving it a good wipe down after a few mins of it 'penetrating' tho as it is really hard to shift!
T
T
