Page 13 of 22
Re: Blinky 51/480
Posted: Thu Dec 07, 2017 6:03 pm
by arthuy
Fitted a new set of headlamp bulbs to the 480.
I had found the headlamps on one of my other cars were poor and a fellow forumite had posted some info on a bulb upgrade.
I bought a couple of sets of Osram Night Breaker (unlimited) H4 bulbs. So far I am quite impressed and they were only £13 a pair.
https://www.osram.com/am/am_com_ledrivi ... aign_4.jsp
Re: Blinky 51/480
Posted: Fri Dec 08, 2017 6:00 pm
by arthuy
Tried to get a photo of the new lamps.
Definitely an improvement over the standard H4 bulbs.
Re: Blinky 51/480
Posted: Fri Dec 08, 2017 11:04 pm
Good to know!
/adds to amazon wish list and hopes that 'er indoors notices....
However, There's already a big pile of "to be fitted parts" building up!
Re: Blinky 51/480
Posted: Sat Dec 09, 2017 11:37 pm
by arthuy
Due to complaints from my other half, I need to sort out the boot lock.
It is soo much hassle to open the door and pull the lever apparently.
The key goes in but doesnt turn, could be a replacement lock in the past but how hard and how do you removed the barrel?
Re: Blinky 51/480
Posted: Thu Dec 28, 2017 11:43 pm
by arthuy
The boot lock still hasnt been looked at, will try and figure it out in the new year.
We havent used the car for a couple of day over Christmas and I was a bit apprehensive about, but I am pleased to say that I it started first turn of the key. Not bad considering the hard frost.
Glad to say that Volvo did a cracking job on the heaters, mine get toastie very quickly which is a bonus in this weather.
Re: Blinky 51/480
Posted: Mon May 07, 2018 11:08 pm
by arthuy
Changed out the rotor and distributor cap.
Well overdue by the look of it.
The metal had signs of erosion and pitting on both the cap and the rotor, usually I keep the old parts for spares but I think that these are fit of the bin.
Re: Blinky 51/480
Posted: Thu May 10, 2018 9:12 pm
by arthuy
So I this time last year I was an aspiring 480 owner and now I have 2, one left hand drive and one right hand drive in the same colour.
I wasnt really in the market for a spares car but this one is the same model as my own.
I have already robbed a few parts for Blinky, the boot release lever and bonnet release lever plastic. The rear screen washer is intact so this will be getting swapped over, worth getting the car just for these bits.
Just a plan for now but I fancy deconstructing the body panels especially the rear quarter panels, these ones have had some filler and paint but could make excellent repair panels with a bit of work of the vehicle.
Re: Blinky 51/480
Posted: Sat May 19, 2018 4:30 pm
by arthuy
Manage get a few bits of my spares car today.
The door glass seals were better than mine so they have been swapped. Also the rear plastic trim on my car had 2 extra speakers and some clips were missing so I wanted to replace so whilst I was in there I took the boot lock out, stripped cleaned and greased so now works a treat.
My drivers door pocket had broken and I found a decent on in the spare car so got that fitted. My door stay does work and I found the spring thing floating about. I guess the mounted bolts are welded to the door and have broken free. Will need to look at welding it back on at somepoint.
Also topped up the Aircon gas, I suspect that when the timing belt was last done they let the gas out. So far no leaks.
When I trial fitted the load cover it was filthy so I gave that a wash too.
Re: Blinky 51/480
Posted: Sun May 20, 2018 3:39 pm
by arthuy
Forgot to ask, My rev counter has started to go intermittent.
Is there a sensor or wiring that usually goes?
Re: Blinky 51/480
Posted: Tue May 22, 2018 12:35 pm
by arthuy
Does anyone have a cd changer mounted under a seat? I am thinking about relocating mine. Do you need brackets or is there something on the seat frame that will accommodate it?
Re: Blinky 51/480
Posted: Tue May 22, 2018 1:10 pm
by brinkie
arthuy wrote: ↑Sun May 20, 2018 3:39 pm
Usually it's either a broken soldering or an interrupted circuit trace on the main board of the instrument cluster (or both...)
Re: Blinky 51/480
Posted: Wed May 23, 2018 2:28 pm
by arthuy
Thanks Robert,
I will have a look, at least I have a spare dashboard I can use to test/compare. Does the signal come via the ECU or is there another pick up which goes direct to the rev counter?
Colin
Re: Blinky 51/480
Posted: Thu Jun 14, 2018 10:44 pm
by arthuy
I have been snowed under the last few weeks and have driven my car for the first time in a couple of weeks.
The interior light fell off, probably due to the heat. I could have used a could of washers to repair but I had one on the spares care so was a good excuse to get down to see the what else I could get off.
Manage to get a good seat belt extension, interior light, rear washer jet, nose cone, and a few odds.
I took the front bumper off to liberate the front foglamps. I used a drop of oil from the dip stick on the threads of the bumper bolts as I didnt have any WD40 to hand. All 4 bolts came off easily and i was very pleased how solid the bar is, the one on my car is in need of a repair so will get this a lick of paint. Hopefully the rear will be in a similar condition.
Re: Blinky 51/480
Posted: Wed Jul 25, 2018 10:03 am
by arthuy
Managed to get round to the MOT today and it passed ok.
I do as a matter of urgency need to sort the power steering pipes out. Has anyone had some made up? or know a supplier?
I reckon mine will break when I try to remove them.
Re: Blinky 51/480
Posted: Wed Jul 25, 2018 11:07 am
by arthuy
Are the left and right hand drive PAS hoses the same? I might be missing something in the parts book.
I will probably be able to get the pipes off the LHD car and have them made up locally but dont want to waste time if they are completely different. I would think that they are similar but with a longer rubber ?
Re: Blinky 51/480
Posted: Thu Jul 26, 2018 11:39 am
by Alan 480
They'd be the same? (but different)
LHD will be longer across to the point where they go onto the rack (next to the column)
so I guess I'll have to get mine made up. if you are using them from the spares car
bloke I have a beer with reckons best option is to go flexible from rack to return (ie only need a hose tail at rack)
then flexible ALL the way from rack to rigid pipe at front of engine (well that's the plan) probably with smaller dameter line and go over top of bellows and sweep back in, using right angle fitting to point hose out to side.
numerous cable ties/fittings to keep in place
mine are also 'very rusty'
Re: Blinky 51/480
Posted: Thu Jul 26, 2018 7:48 pm
by arthuy
Thanks Alan,
What my plan is if they are the same is to take them off and get a new set or 2 made up at a place locally to me. I think I have a better chance of getting the LHD ones off as mine are crusty and wouldn't survive removal.
I will keep you posted.
Re: Blinky 51/480
Posted: Fri Jul 27, 2018 3:03 pm
by frenchfries
Just in case, of part 16 is beyond repair it can be by-passed without side effect. Mine was just too rusty to be saved.
Re: Blinky 51/480
Posted: Fri Jul 27, 2018 9:35 pm
Part 16 is a very crude oil cooler.
They use similar ones on the early 850's - Not saying they're transplant-able, but you could use any sort of oil cooler arrangement to replace it.
Re: Blinky 51/480
Posted: Sat Jul 28, 2018 9:43 am
by arthuy
Out of Curiosity, how easy it is to remove the steering rack?
It might need to come out if my pipe fittings are stuck. I have also seen new ones arent that expensive.
