code reader info
doingitsideways
code reader info
Post by doingitsideways » Sat Apr 19, 2014 11:06 am
Hi,
I can't seem to find the thread with all the meanings of fault codes anywhere.
Can someone please post me a link?
Trying to figure out why my new (Jamesy12345's old) Turbo won't idle.
I have MANY codes to look up! :(
Thanks,
Steve :hopping:
Hammers can't fix a 480!!!
doingitsideways
Re: code reader info
Post by doingitsideways » Sat Apr 19, 2014 12:52 pm
Edit:
Think I've found what I need after a bit of digging.
Seems I have many ABS faults, but none on the fuel ECU...
Bizarre.
Ah, the joys of 480 ownership! ;)
Steve :hopping:
Post by glasgowjim » Sat Apr 19, 2014 11:19 pm
Fault Codes Retrieval
1. Open the diagnostic system's box cover and place the test cable mounted on the side of the box into an appropriate socket.
2. Turn the ignition ON to key position II without starting the engine. Wait about ten seconds.
3. Press the button once and hold it for more than one but less than three seconds.
4. The LED lamp will flash in successive series of three digits followed by a three-second pause. If there are no fault codes stored, it will flash 1-1-1 indicating the system being tested is operating correctly.
5. Count the successive flashes and record the fault code.
6. Press the button again, as described above.
7. Record the fault code. If it is the same as the previous one, then no additional codes are stored. Repeat until all the codes stored are retrieved (often a maximum of three).
8. Turn the ignition OFF and remove the test cable from a socket.
Erasing Fault Codes
1. Repeat step 1 and read all the fault codes again. Do not turn the ignition OFF after read-out.
2. Press and hold the button for more than five seconds, then release it.
3. When the LED lights, press the button again for more than five seconds and release it. When the LED goes off, the memory is cleared.
4. Test that memory is cleared by performing step 1. Code 1-1-1 should be returned.
Note: erasing fault codes on the ABS socket will cause the ABS control to be lit. It will turn off after a test-drive with speed of more than 40 km/h.
Sockets Description
1 – alarm and remote locking system,
2 – fuel system,
3 – ABS,
6 – cruise control,
7 – SRS (airbag).
Hints
Before assuming a fault in any of the systems tested, try to erase fault codes as described above. In my case, open circuit in ABS wiring has initially been signalled with codes 122, 152, 312 and 322. After erasing and performing a test-drive, only code 312 was signalled.
At first, read the codes when the engine is completely cold. Then, go for a longer test-drive and read them all again while the engine is still hot. Some codes (especially these related to lambda-sensor) tend to appear only while the vehicle is driven and short time afterwards.
Socket 1 — Alarm and remote locking system
Code:
1-1-1 No error code set
1-1-3 Transmitter to receiver: weak signal
1-1-4 Control Module (CM) faulty
2-1-1 Relay contacts, fuse or ground terminal (locking)
2-1-2 Relay contacts, fuse or ground terminal (unlocking)
2-2-1 Fuse or ground terminal (locking)
2-2-2 Fuse or ground terminal (unlocking)
2-2-3 Codes 2-2-1 and 2-2-2 combined
3-1-2 Siren: internal fault
3-2-1 Siren: power supply
4-1-2 Ultrasonic system: internal fault
4-1-3 Ultrasonic system: one or more sensors faulty
5-1-1 Key switch ground on (> 10 seconds)
5-1-2 Key switch ground off (> 10 seconds)
5-1-3 Locking door with ignition on
5-1-4 Unlocking door with ignition on
5-2-1 Central locking system switch (> 10 seconds locked)
5-2-2 Ultrasonic switch (> 20 seconds locked)
5-3-1 Interior lights, shorting to earth
Socket 2 — fuel system
Code:
1-1-2 Malfunction in Electronic Control Module
1-1-3 Open circuit in injector wiring
1-2-1 Air pressure sensor: no signal correspondence
1-2-2 Air temperature sensor: no signal or signal faulty
1-2-3 Coolant temperature sensor: no signal or signal faulty
1-3-2 Incorrect battery voltage
1-4-3 Knock sensor: no signal or signal faulty
2-1-2 Oxygen sensor: no signal or signal faulty
2-1-4 Flywheel sensor: signal faulty
2-2-2 System relay coil: no voltage
2-2-3 Idle speed regulating valve: no signal or signal faulty
2-3-1 Adaptive Lambda closed loop control system lean or rich in part–load range
2-3-2 Adaptive Lambda closed loop control system lean or rich at idling speed
2-4-4 Knock sensor: no signal or signal faulty
3-1-1 Speedometer signal: no signal correspondence
3-1-3 Charcoal absorption canister valve: signal faulty
3-4-2 A/C relay signal: signal faulty
3-4-3 Main relay coil: no voltage
4-1-1 Throttle valve sensor: signal faulty
Socket 3 — ABS
Code: (40 km/h = 25 mph)
1-2-1 Left side front wheel sensor: faulty signal at speed less than 40 km/h
1-2-2 Right side front wheel sensor: faulty signal at speed less than 40 km/h
1-2-3 Left side rear wheel sensor: faulty signal at speed less than 40 km/h
1-2-4 Right side rear wheel sensor: faulty signal at speed less than 40 km/h
1-2-5 Signal faulty from at least one sensor for a long period
1-3-5 Control Module (CM) faulty
1-4-1 Faulty pedal sensor: shorted to ground or supply
1-4-2 Faulty stop (brake) lamp switch: open circuit
1-4-3 Control Module (CM) faulty
1-4-4 Brake discs overheated
1-5-1 Left side front wheel sensor: open circuit or short-circuit to battery voltage
1-5-2 Right side front wheel sensor: open circuit or short-circuit to battery voltage
1-5-5 Rear axle sensor: open curcuit or short-circuit to battery voltage
2-1-1 Left side front wheel sensor: no signal or moving off
2-1-2 Right side front wheel sensor: no signal or moving off
2-1-3 Left side rear wheel sensor: no signal or moving off
2-1-4 Right side rear wheel sensor: no signal or moving off
2-1-5 Valve relay: open circuit or short-circuit
2-2-1 Left side front wheel sensor: ABS operation signal missing
2-2-2 Right side front wheel sensor: ABS operation signal missing
2-2-3 Left side rear wheel sensor: ABS operation signal missing
2-2-4 Right side rear wheel sensor: ABS operation signal missing
2-3-1 Left side front wheel sensor: signal missing
2-3-2 Right side front wheel sensor: signal missing
2-3-5 Rear axle sensor: signal missing
3-1-1 Left side front wheel sensor: open circuit or short-circuit
3-1-2 Right side front wheel sensor: open circuit or short-circuit
3-1-3 Left side rear wheel sensor: open circuit or short-circuit
3-1-4 Right side rear wheel sensor: open circuit or short-circuit
3-2-1 Left side front wheel sensor: irregular interference at speeds over 40 km/h
3-2-2 Right side front wheel sensor: irregular interference at speeds over 40 km/h
3-2-3 Left side rear wheel sensor: irregular interference at speeds over 40 km/h
3-2-4 Right side rear wheel sensor: irregular interference at speeds over 40 km/h
4-1-1 Left side front wheel inlet valve: open circuit or short-circuit
4-1-2 Left front return valve: open circuit or short-circuit
4-1-3 Right side front wheel inlet valve: open circuit or short-circuit
4-1-4 Right front return valve: open circuit or short-circuit
4-1-5 Rear valve: open circuit or short-circuit
4-2-1 Rear wheel circuit inlet valve: open circuit or short-circuit
4-2-2 Rear wheel circuit return valve: open circuit or short-circuit
4-2-3 Traction Control System (TRACS) valve: open circuit or short-circuit
4-2-4 Pressure switch for TRACS: faulty or short-circuit
4-4-1 Control Module (CM) faulty
4-4-2 Pump pressure low
4-4-3 Pump motor/relay: electrical or mechanical fault
4-4-4 No power supply to valves in hydraulic unit
Socket 6 — cruise control
1-1-1 No error code set; speed was higher than 40 km/h
1-1-2 Vehicle Speed Sensor: abnormal signal received
1-2-2 Vehicle speed: 40 km/h not exceeded or no signal
2-1-1 Fault in supply voltage or Control Module
2-1-2 Circuit to vacuum pump or regulator: signal faulty
Important: cruise control diagnostics must be done immediately after the test drive. Do not turn the engine off! Codes will not be saved in memory if you do.
Socket 7 — SRS (airbag)
Code:
1-1-2 Internal fault in the sensor unit
1-2-7 SRS warning lamp: open circuit or short-circuit
2-1-1 Steering wheel module: short-circuit in wiring
2-1-2 Steering wheel module: open circuit in wiring
2-1-3 Steering wheel module: short-circuit to the ground
2-1-4 Steering wheel module: short-circuit to +12V
2-2-1 Passenger module: short-circuit in wiring
2-2-2 Passenger module: open circuit in wiring
2-2-3 Passenger module: short-circuit to the ground
2-2-4 Passenger module: short-circuit to +12V
2-3-1 Left seat belt tensioner: short-circuit in wiring
2-3-2 Left seat belt tensioner: open circuit in wiring
2-3-3 Left seat belt tensioner: short-circuit to the ground
2-3-4 Left seat belt tensioner: short-circuit to +12V
2-4-1 Right seat belt tensioner: short-circuit in wiring
2-4-2 Right seat belt tensioner: open circuit in wiring
2-4-3 Right seat belt tensioner: short-circuit to the ground
2-4-4 Right seat belt tensioner: short-circuit to +12V
(no code) SRS warning lamp in the instrument panel does not light
(no code) Fault in diagnostic output
Thanks to: http://www.am.torun.pl/~ja/volvo/diagno ... stem.shtml
Post by Alan 480 » Fri Feb 28, 2020 12:51 pm
Any ideas why I cannot get the error code thing to work ?
I can get the error code reader to work on the old one EVA, no codes signalled (ie 1 1 1)
on NORA the LED doesn't light up when turn on ignition (old one it comes on then goes off after short time similar to time taken for fuel pump is primed?)
note that I can see a 'glimmer' of light from the LED depending if plugged into another socket so it proves that the LED does function AND the lead is intact.
to encourage my laziness , can the whole module be unplugged from the loom at the wheel arch or is 'part of the loom'
then I could swap modules from EVA to NORA , but maybe it is only a 'terminal block' with a push button?
Edit
so the module DOES unplug from the loom :-)
mine has ONLY pins 2, 3, 5 , 7 NOT 6 i don't have cruise or remote locking on either car
the button was crsuted up on NORA, but a quick dismantle and all is good, well the module is now on EVA.
a few extra hints regarding the code reader.
when the cable is plugged in initially the LED lights at half brightness
ignition to position 2 and LED goes out
when press button the LED illuminates (if it doesn't assume button pegged)
after code is read the LED stays off until ignition has been off for about 6 - 8 seconds, the same reset time as the fuel pump?
and NO error codes on the fuel system
