Any idea where I can get a MAF to turbo hose, or is there a good after market replacement solution? Mine has a rip at the bottom.
Hose is the 2nd photo in this thread
http://www.volvo-480-europe.org/forum/v ... =11&t=4644
Someone please help
MAF hose
Re: MAF hose
Bump
Re: MAF hose
I have replaced mine with a series of aluminium and silicone pipes. You'll need one 90 degree aluminium pipe with same outer diameter as turbo, another 90 degree with same diameter as MAF, a silicone reducer for both and 2 straight couplers. I have then welded a small piece of pipe to make a fitting for the idle control valve.
I'll try to take a photo and post it when i have some time.
Re: MAF hose
Thank you
