Rear defroster
Rear defroster
Have the wires in the rear window have stopped working, they don't heat anymore so it only sort of gets half defrosted <!--EZCODE EMOTICON START :| --><img src=http://www.ezboard.com/intl/aenglish/im ... ferent.gif ALT=":|"><!--EZCODE EMOTICON END--> <br>Does anyone know what the cause could be and how one can fix this? <p><!--EZCODE ITALIC START--><em>Volvo for life, 480 for eternity.</em><!--EZCODE ITALIC END--></p><i></i>
Re: Rear defroster
I meant "half the wires" of course... <p><!--EZCODE ITALIC START--><em>Volvo for life, 480 for eternity.</em><!--EZCODE ITALIC END--></p><i></i>
- dragon
- Volvo 480 Club Europe CREW
Re: Rear defroster
I wouldn't mind knowing what the options are for this too, annoyingly, only one of my wires doesn't work - the one that clears the strip at my eye level! typical <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <p><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE ITALIC START--><em>1995 480 Turbo, Flame Red Metallic, Jacquard/Leather</em><!--EZCODE ITALIC END--></p><i></i>
Re: Rear defroster
its normally that the wire has got a break in it somewhere eg the glass has got sratched and cut the wire on the glass, i have the same problem and when i checked with a meter found that there was a break in each wire that was not heating so i had to get a replacement rear window <p></p><i></i>
Re: Rear defroster
hmm... strange, that's what I thought it might be but I can see no place where these wires are cut.<br>As for replacing the rear window, that's a rather expensive proposition, especially if it's just for the darn defroster! <!--EZCODE EMOTICON START 0] --><img src=http://www.ezboard.com/intl/aenglish/im ... /alien.gif ALT="0]"><!--EZCODE EMOTICON END--> <p><!--EZCODE ITALIC START--><em>Volvo for life, 480 for eternity.</em><!--EZCODE ITALIC END--></p><i></i>
rear demister
I had the same problem with another car I had ( Morris Marina Coupe - rest its soul ), and have lost 3 wires on my baby celebration.<br>Probably due to my dog or over exuberant cleaning.<br>Any-hoo, I got this small vial of liquid metal from a motor factors which was made for the job, so I painted over the break and "voi-la", complete circuit.<br>I haven't bothered to fix these 3 wires, but I'm going to look for another vial to do the job.<br>You should see the break in the wire when you start the demister; look along the dead wire and you should see a tiny clear spot where the current seems to be trying to cross the gap. I know 'cause I've seen it.<br>Good luck<br>Gedda<!--EZCODE EMOTICON START 8o --><img src=http://www.ezboard.com/intl/aenglish/im ... s/nerd.gif ALT="8o"><!--EZCODE EMOTICON END--> <br> <br> <p></p><i></i>
Rear window defroster
Evening,<br><br>This is an ancient problem, and there used to be a special paint available to 're-touch' the scrathced filament. Use a test lamp, and a piece of tinfoil to find the break, and try to use a high-solid metallic paint to re-paint the line. It might work, it might not.<br><br>Phil<br> <p></p><i></i>
