Pop up lights failing
volviq
Post by volviq » Sat Nov 30, 2002 7:55 pm
Hi <br>I have problem with pop up lights which dosen`t work <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/im ... /frown.gif ALT=":("><!--EZCODE EMOTICON END--> <br><br>Anyone can help me with some suggestions about the problem? <br><br> <p></p><i></i>
member81
pop up lights
Post by member81 » Sun Dec 01, 2002 8:49 am
Hello Volviq<br>Can you be more specific as to what the problem is?<br>.......john <p></p><i></i>
volviq
re:
Post by volviq » Sun Dec 01, 2002 1:55 pm
Thanks for your answer<br><br>They will not pop up! They are totaly dead. <br>what can it depend on? <br><br>regards <br><br> <p></p><i></i>
levensnevel
Pop up popped out
Post by levensnevel » Sun Dec 01, 2002 2:34 pm
IQ,<br><br>go 2:<br><!--EZCODE AUTOLINK START--><a href="http://www.volvo-480-europe.org/index2. ... <!--EZCODE AUTOLINK END--><br>select :480 questions (FAQ)<br>choose: Manually pop up your lights<br>and take it from there<br><br>Hope it's just a blown fuse <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br><br>Levensnevel <p></p><i></i>
member81
pop up lights
Post by member81 » Sun Dec 01, 2002 4:35 pm
hi<br>The pop up lights are controlled by a relay, situated under the cover in the engine bay.On my car the unit is located on the top of the bulk head above the fuse box on the drivers side (uk).<br>I have suffered the same problem which started with an intermittent problem, it would only happen on the odd occasion.When the lights were down and the light switch was put on, then the headlamp bulbs lit up the ground under the car.when I manually raised the lights and then closed the bonnet, then the lamps retracted.<br>The local dealer fitted a new relay for only a small fee above the cost of the part....no problems since....hope this helps....john <p></p><i></i>
Stefan
Re: pop up lights
Post by Stefan » Sun Dec 01, 2002 4:54 pm
you could try to "tab" on the lightswitch itselve,<br>mine went dead a while back to.. "my" problem was a little worn light switch<br><br>Bye<br> <p></p><i></i>
volviq
re:
Post by volviq » Sun Dec 01, 2002 6:46 pm
Hi <br><br>thanks for your kind answers <br><br>but when I checked all one more time and the fear <br>lights are not work either . also the pop up lights don´t<br>pop up and the fear lights are not working. <br><br>I fear light lamp in the control panel dosen´t work either.<br><br>I have a 1997 ES if I should change the relay so which <br>of them I should change? <br><br><br> <p></p><i></i>
member81
pop up lights
Post by member81 » Mon Dec 02, 2002 7:47 pm
Hi<br>The volvo part code according to my bill is 3412653-2. The cost in 2000 was about 30 euros. I'm not sure, but the location of the relay should be indicated under the bulk head cover.<br>If you have a problem finding it, I will check mine at the weekend.........john <p></p><i></i>
volviq
re:
Post by volviq » Mon Dec 02, 2002 9:10 pm
Thanks John<br><br>I will try to fing and buy it. If it´s any problem then <br>I write about it here.<br><br>Thanks again <br><br>best regards <p></p><i></i>
vins480t
Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
Hood switch
Post by vins480t » Tue Dec 03, 2002 11:27 am
I had a similar problem a while ago and I checked everything metioned b4. After a while I found out the hood switch was broken and that made the lights stay down. It works the same way around when you want to wash the popup without them being on. You just popup the lights and the pop the hood the popup stay up and you can switch of the lights.<br><br>Vinciente <p></p><i></i>
