That doesn't go yellow with age. It's for the clear rear reflectors. I took the old ones off and the Araldite (spelling) i used made them go that orangey colour round the edges:
Anyone know of a good glue that won't go yellow/orange, but is good enough for outside conditions?
I need a glue...
- Dan the 480 Man
I need a glue...
- Dan the 480 Man
They do, but not on the reflector. The reflector is glued to the white plastic mount thingy, and the rubber gasket sits underneath that.
Is this external grade stuff fairly strong then? And is it expensive?
- ozturbo
The best glue for acryllic, which is what lights are made of, is Weldon Cement. It is made in the US and is used in the plastics industry. Acryllic is very difficult to glue successfully with anything else. I bought a tube of it from a plastics company here in Adelaide. I looked it up on the internet and they were second on the list. It is not available in hardware stores. It is supposedly carciogenic so you need to wear gloves, but it works like a charm and a little goes a long way.
1990 Volvo 480 Turbo white
1988 Alfa 75 3 litre V6 red
1990 Alfa 75 Potenziata 3 litre V6 black
1992 Alfa 164 3 litre V6 red
1981 Alfa GTV 2 litre red
- kennymac
- Location: In the poor hoose due to cash hemoraging from bank to Isuzu Trooper!!!!
When the lens came of one of my long range driving lamps, I just used ordinary clear silicon sealant such as you would buy in a DIY shop (just make sure its the stuff that smells of vinegar and not the acrylic stuff, as the acrylic is water based) and it worked a treat, you just have to make sure everything is spotlessly clean and dry.
Kenny
Kenny
Y reg mk1 XR2 - braw fun, now departed
H reg 480 ES Just Goes, now departed
M reg 480 2.0l S (Chassis No 592056) Even better, still going (for now)
Thinking about a turbo - it's all your fault, mind you, saw a black XR4i the other day...........
