FAO: richmod owners
FAO: richmod owners
I was driving my richmodded 440 earlier, I was giving it some encouragement but according to the boost gauge, it didn't seem to be boosting as high as it has done previously. It was boosting to near the end of the yellow but no further, though in the past it has boosted to the end of the red. The car did seem slightly slower than it has done in the past.
I had just filled the car up this morning, and the temperature outside was reading around 29c, could these factors be affecting it? or do i have a problem? Turning off the aircon didn't make much difference to the performance.
Any ideas?
Ed
Any ideas?
Ed
440 GLT Turbo
- Brasco
I've had this... I thought it might bo the temperature too.
I found that resetting the ECU helped.
It will back off the boost and enrich the mixture - to stop the engine melting - if the combustion temperature gets too high. Which is likely to happen in this kind of heat as the charge air is cooled by the intercooler, warmer ambient temp = less cooling ability.
Also why the turbos on a dyno don't perform as well as hoped, the fans can't cool the intercooler anything like as well as the ram-air effect of 90mph driving for example.
- guitarcarfanatic
Mine has done exactly the same thing! Can just about tease 2 needles width of red out of her at 4500rpm in 4th. Everything else is right in between the yellow/red. Come on cold weather!!! I though it was teh crap petrol I put in at first but after a bit of super and a reset same thing! Car does still shift mind. Still spools up boost quicker etc than before
Previously...
1989 Black ES - Great runner
Previously...
- Big Brother
- Moderator
- robin_xr4i
Hell yes, nice cool dense air! The foggier the better, watch the boost gauge off the end of the redguitarcarfanatic wrote:Come on cold weather!!!
- haz@nocturnal_development
- 480 Rookie
not got the rich mod but both ecu'd have been played with by overboost, no problems in this weather, still running optimax and 21psi. been to brunters for a few laps on a track day on sat, and pod for 5 runs on sunday and barr the plugs foulin up in the queue due it bein rich at idle, not a problem.
maybe its the ecu 'learnin' that you don't drive it that hard so it may have lowered the settings, maybe some high speed motorway journey's will sort it, or so its rumoured.
i can see a few degrees rising the engine coolant temp but blowing up?? 600+ degrees in the cylinders, don't think an extra 10 or so would affect it.
haz
haz
reanualt 5 campus, Volvo turbo conversion, hybrid T28, -31 actautor, external oil cooler, THS intercooler, rear radiator, large throttle, Adaptronic ECU, cossie blue injectors. results recorded '06 (21 psi 228bhp/229lbs),(23psi 12.6 @108mph)
- Brasco
No, definately not mate, I reset the ECU over in Germany in a service station, was driving it on the autobahn, and really needing to floor it quite often (and cruising at 120mph most of the time), but after a while the boost wouldn't go into the red.haz@nocturnal_development wrote:maybe its the ecu 'learnin' that you don't drive it that hard so it may have lowered the settings, maybe some high speed motorway journey's will sort it, or so its rumoured.
richmod
How high should the turbo boost gauge go with the rich mod?!?
greetz
greetz
- Brasco
To the end of the red.
red end
Where to look and what can I do to find why in my :
1990 turbo
1989 turbo the gauge only goes half orange ?!?
thanks and greetz
1990 turbo
thanks and greetz
- levin
Re: red end
Is your car rich modded?V480TI wrote:Where to look and what can I do to find why in my :
1990 turbo
thanks and greetz
My 1989 turbo went to the end of the yellow when it was fully stock. Now it goes to the end of the red
[img]http://jdmtech.net/levin/imagens/assinatura.jpg[/img]
[size=75]
My Volvo 480
[b]Name[/b]: Volverine // [b]Type[/b]: TURBO // [b]Year[/b]: 1989 // [b]Colour[/b]: Black Metallic // [b]Engine[/b]: B18FT (1.7), Manual // [b]Mods[/b]: Pollux Black Metallic; Voodoo III MBC[/size]
[size=75]
My Volvo 480
richmod
Yes, it is rich modded.
Funny that everybody tells that the gauge always goes towards the red.
but nor in my 1990 or 1988 turbo this happened.
They (both) went halfway orange.
But :::::::: It was a lot quicker then standard, that is obvious for me.
Now I am beginning to think that it can be even more quicker.
But how to fix the problem ?
The Rich ECU is now in my 1988 turbo manual.
I noticed a few days ago that wenn I floor the pedal (so that the turbo comes in) and shift gear up ( and do not exceed 2500 rpm's or so)
I hear a component in the engine bay either passing or losing air, with a sound that is something like a dumpvalve but much quiter.
I didn't had this in my 1990 turbo.
1990 turbo : orange ecu
1988 turbo : purple ecu, now a orange richmodded on with problems.
Thanks and greetz
Thanks and greetz
- guitarcarfanatic
Ok well this is annoying me! My car is filled with optimax, reset ECU, and the weather is cold today. It just wont boost into the red!!!!!
I'm thinking...
Plugs (They are standard plugs so maybe cant cope with the extra heat meaning teh ECU is backing off...I have done rotor arm, dizzy cap etc and the leads look in good codition!)
TPS sensor? I know Robins car had a problem where it would only boost standard because of it.
Boost leak? I have checked all the pieps as well as can and I cant see or hear any leaks.
The car is still loads quicker than standard...It just have the same kick as it did to start with! Any other suggestions or advice on how to test? Do any of these reasons sound plausible?
Cheers for any advice.
Rob
I'm thinking...
Rob
Previously...
Previously...
- guitarcarfanatic
Thats above the oil seperator on the front of the engine right? How do I test it?
Cheers,
Rob
Cheers,
Rob
Previously...
Previously...
- Brasco
Don't mean to rub it in mate, but I noticed mine go right off the scale today, didn't know it went that far.
guitarcarfanatic wrote:Ok well this is annoying me! My car is filled with optimax, reset ECU, and the weather is cold today. It just wont boost into the red!!!!!
I'm thinking...
Rob
I'm getting similar symptoms. Its boosting higher than standard, but not much into the red. The car is quicker than standard, but not as quick as it used to be. Whats going on?
Ed
440 GLT Turbo
