What to do when scrapping a 480
- Brasco
Hi all,
I notice quite a few people have experience in scapping a 480. I was wondering if anyone has advice on which bits to try and salvage before it goes to 'steel cube heaven'?
I'm thinking more about inside the engine bay area, because I know the things worth taking out of the cabin/bodywork.
Oh, it's a Turbo by the way.
- Big Brother
- Moderator
- guitarcarfanatic
Look in the yellow pages for a metal scrap merchant. I got £50 for scrap metal for my last one!
Previously...
1989 Black ES - Great runner
Previously...
- Brasco
Guy's, I guess I should have worded the title better!!!
I've scrapped cars before. Before I scrap this one, I was just wondering what are the best (and easiest) bits to cherry-pick out of the engine bay.
MAF is a good call, I suppose the idle valve could be useful. Unfortuately the turbo is goosed, which is part of the reason it's being scrapped.
Is the CEM worth pulling out?
- Brasco
Indeed, winter showed that she leaks like the elderly lady she is.sallysal wrote:Is that The Baroness you're scrapping Ad? saw her at Lincoln -poor old girl
Sx
(I say that, she's actually only a J, but the body on them whitey's is prone corrosion)
- Ally
Take as much as you have room to store would be my simple answer. You never know when something's going to fail and it can make keeping your good car on the road significantly cheaper.
It also depends on how much time you can afford to spend stripping. If you can't keep the whole engine strip off all the ancillaries like alternator, starter motor, power steering pump, ignition module, MAF, any sensor you can get your hands on, (lambda sensor, flywheel sensor, gearbox speedo sensor, temp. sensors, radiator cooling fan switch), maybe the mega-fuse, the throttle body, header tanks, washer bottle, pop-up motors. And anything else that looks like it'll come off easily like every relay out the relay box on top of the bulkhead. Might also be worth taking the brake calipers (especially the back ones).
Hope this helps...
Hope this helps...
- Brasco
It does Ally, thanks.Ally wrote:Hope this helps...
- VanDerGraaf
I was going to suggest some things but that is the perfect advice really.
I have to go up to the spares Turbo and take off some major body parts soon as well as the turbocharger and some of the decent engine bits that are left!
Previously:
'97 Saab 9000 Aero gone
Grey '88 ES dead
Previously:
Grey '88 ES dead
- robin_xr4i
Safe everything in the engine bay turbo, lump, head, box, sensors the lot!
Like Volviz said put it under the bed!
