I need your help
I need your help
I would like to have a 480 in a game (rFactor). I'm working on the 3d model (I'll post here some pics soon). I have to do almost everything yet, but I'm setting up the physics a bit.
So I need as much info as possible of stock suspension and, if possible, modified ones by volvo and as many manufacturers as possible (bump and rebound travells, bump and rebound bump stiffness, spring stiffness, anti-roll bar stiffness, toe in and caster (if possible in cm).
I need power/torke curves of: 1.7 non turbo and as much modifications (chips, T3, etc) as you can find.
Sounds of all engines (modified and stock ones) are needed too: starting up, medium and high acceleration (in 3th or 4th), idle, mantaining 1000, 1500, 2000, 3000, 4000 and 5000rpm.
I know I'm asking too much but where cand I find this if not here?
If you want to contact with me or chat in messenger my adress is crazivant [@] hotmail.com
Thanks in advance for your help and sorry for my english
I'll try to look for power/torke curves of: 1.7 non turbo and turbo model.
PS. change steering wheel This one is from 440, in 480 they were different
anyway good job
anyway good job
-'87 480 ES red
-'87 480 ES red
- coyote1980
- Volvo 480 Club Europe CREW
Eee I thought about it and airbag sw's arms are more straight.coyote1980 wrote:Unless you had an airbagMilosz_480 wrote:PS. change steering wheel This one is from 440, in 480 they were different
anyway good job
See an example:
Airbag SW:
non airbag SW:
I hope I made myself clear
-'87 480 ES red
-'87 480 ES red
- coyote1980
- Ettore Bugatti
rFactor is better than Racer. Here you've got a pair of videos of volvo 300:
http://www.youtube.com/watch?v=idiCowaK99Q
http://www.youtube.com/watch?v=j7srDnnFdEA
I need the next sounds:
starting up, medium and high acceleration (in 3th or 4th), idle, mantaining 1000, 1500, 2000, 3000, 4000 and 5000rpm, and, if possible, on the rev limit.
Thanks a lot!!
Thanks a lot!!
- Katy-Felicity
Cool
Wow it looks fantastic!! Can't wait to see end results!
Volvo's Always and Forever
Volvo 480 S 'Little Blue'-Black Leather, webasto sunroof and pink wipers!-I love her!
Volvo 480 Celeb-Flame red, '95-Getting some TLC
Volvo 480ES Limited Edition-Paris Blue with two tone leather getting TLC and parts from other 480 Paris Blue-Turbo, organ donor
Volvo 480 ES - silver, '88- organ donor
- hjkort
haven't measured it, but I can check for you. Do you need the Force acting on the wheels per degree of bodyroll or would you like the dimensions of the swaybars?CrazIvant wrote:Anything about anti-sway bar stiffness?
If needed I can also give you the (global) dimensions of the suspension front and rear.
At the momment, the only thing I need is antiroll-bar stiffness in N/mm, diameter and power. I don't know exactly what power means, but it says that:
The car has now a quite realistic handling I think. As soon as possible, I'll rec a video for you to analyze
Thanks a lot for your help!!
I'm reading and learning about suspensions...FrontAntiSwayRate=(1.11e11, 4.0) // (base, power), so rate = base * (diameter in meters ^ power)
looking good, must have taken a lot of effort to get it to that stage...
tho i'd hate to break it to you, there is one fatal floor in the model, i'm sorry to tell you, but youve drawn it with the steering wheel on the LHS, unfortunately the only side that you could ever consider steering on is on the RHS, whilst driving on the LHS of the road.
I know it is going to take a lot of effort to change it all, but thought i better tell you now before you think it's almost finished!
Nah nice job nice to see someone putting in the effort
Ian
PS. yes i know where he comes from, and the sort of joke is intentional, no matter how unfunny it is...
Ian
[url=http://s52.photobucket.com/albums/g17/muddyfox470/480bilt/][img]http://www.sloganizer.net/en/image,480ES,white,black.png[/img][/url]
[url=http://s52.photobucket.com/albums/g17/muddyfox470/480bilt/]'93 480ES 2litre - Steel Grey Metallic - 70k Miles - Bought March 07 :P[/url]
(Click for pictures :D )
