Radio Code
Frank Naylor
Radio Code
Post by Frank Naylor » Thu Sep 22, 2005 8:46 pm
Every time I turn off my radio I have to enter the code when I turn it back on. The radio stays on after the ignigtion is turned off and the key removed. any one have any idears? Every thing else on the car is working perfect after fixing info centre, rear lights and a show room polish,would put a pic on here if I knew how.
Frank
480 Revisited
Brasco
Post by Brasco » Thu Sep 22, 2005 8:54 pm
yeah, it's not connected to the ignition.... :D
Frank Naylor
Radio Code
Post by Frank Naylor » Fri Sep 23, 2005 1:15 pm
Brasco wrote:yeah, it's not connected to the ignition.... :D
Yeah I guessed that much but is it normal and why does it keep asking for the code?
Frank
480 Revisited
reynolds_p1
Post by reynolds_p1 » Fri Sep 23, 2005 1:26 pm
You need to connect the memory wire up, its most likely that the constant (memory) and switched power (ignition) wires are the wrong way round.
Adam
No longer in a 480!
vins480t
Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
Post by vins480t » Fri Sep 23, 2005 1:36 pm
just try to find the constant 12+ and the switch wire and connect them the right way
btw to insert a picture use [ img ] http :// www .yourwebspace/name.jpg [img\ ]
its the img button on the top
Frank Naylor
Radio Code
Post by Frank Naylor » Fri Sep 23, 2005 2:37 pm
Thanks Guys,
Just got to find those wires now,I know there is a spare white connector behind there thats not connected to any thing thought it might be for some accessory!
Frank
480 Revisited
vins480t
Post by vins480t » Fri Sep 23, 2005 2:38 pm
nope that 1 is for the rear speakers
Frank Naylor
Radio Code
Post by Frank Naylor » Fri Sep 23, 2005 3:29 pm
vins480t wrote:nope that 1 is for the rear speakers
Where does the other end come out the I can fit some Speakers in the rear,
Frank
480 Revisited
