Volvo radio code
Volvo radio code
What if you have forgotten your radio code ???
Can Volvo put a new code in without knowing the old one ???
Thanks and greetz
Thanks and greetz
- dragon
- Volvo 480 Club Europe CREW
No, but if it's the original radio in the original car, then any dealer can look up your reg and obtain the code for that radio. Failing that, there's plenty of people with data cables who can simply read the chip with the code on it and tell you what the code is.
Volvo have provided me with the numbers to 2 480 radios and 1 T4 radio without charge. I paid for a fourth radio to be "unlocked" by a man with a data cable - 7 quid.
Gaz Wilson
Gaz Wilson
- Drazyl
I'll second that - I emailled my local Volvo garage and the wanted £10 + VAT (and to see the car) to dig out the code, so I was debating whether I should do that or replace the unit with a CD one. On the way to visit my parents I came across their local Volvo garage and pulled in on the off-chance and asked the girl on reception whether they could retrieve the code, she took a look at the VIN, tapped it into the computer and scribbled the code on a piece of paper, no charge.dragon wrote:No, but if it's the original radio in the original car, then any dealer can look up your reg and obtain the code for that radio. Failing that, there's plenty of people with data cables who can simply read the chip with the code on it and tell you what the code is.
SAAB 9-3 2.0t
(Previously) [b]1994 480 GT[/b] - Metallic Green...
- coyote1980
For a small fee they should be able to dig up the code when you provide a serial number.
Rumour has it that when you put the radio in the freezer for a couple of hours the chip will return to factory-default asking you to choose a security code. Might be a nice one for the Mythbusters, because if it were true people in Northern Europe have a useless security option
I heard it works better if you put it in a microwave.
Stu.
- coyote1980
- coyote1980
- Drazyl
No, you haven't cooked it for long enough, which is why it smells funny. Try another 5 minutes at 100% plus 10 minutes at 60%coyote1980 wrote:Well, after 5 minutes the smell became unbearable, so I discontinued microwaving it. Could it be that the power was set too high?stu chacks wrote:I heard it works better if you put it in a microwave.
Stu.
SAAB 9-3 2.0t
Re: Volvo radio code
Hi, I need the radio serial number in order for the dealer to give me the radio code but can't physically remove the radio-any ideas? It's a volvo radio VC708, thanks very much for any ideas anyone might have
As above if it's OE to the car your reg number should suffice.
Rybrook Volvo just gave me the code for my VC802 but it comes up as an invalid code when I try - very odd. Going to try Daniels freezer trick and if that doesn't work it's 15mins on a defrost setting before I take it to a 'radio decoders'.
Stu.
i have the same problem, a CR906 radio with a incorrect code.
i have two options for everybody:
www.sweden-parts.nl, ask them in english maybe they can help. you will get a email with a confirm.
or:
http://au.geocities.com/OZBRICK850/radio-codes.html
this site gives a manual how to get your code for 2 radio types. i have done the download and opened the radio. tomorow i will try the radio in my car. i will let you know the end of this story
or:
480 ES 1991, 102 PK, dyno 97.5 PK. dutch power
I tried a dealer who said I needed to supply the serial number from the back of the radio but my problem is that I cannot see how to get the radio out in order to see the serial number, thanks for any suggestions
radio removal
It's a factory fitted Volvo radio, VC708, thanks very much for your help
- ozturbo
Radio removal
My radio is a 708. I can't see any of the holes you guys are talking about. Where are they and what do they look like? I need to get it out somehow to put a CD player in. Also the radio code I have has two numbers which are higher than the numbers on the buttons. How do you punch the code in?
