Hi!
Are there someone that knows witch cable is what ?
My radio was cutted from a Volvo 480 .
So I need help so I can install it to my car.
// jimmi.
Radio sr-701 connections
Re: Radio sr-701 connections
was tring to upload a pic
If you have the 3x3 big radio connector in your dashboard you can either buy a ISO-connector to make it fit, or build one yourself:
Not all shops sell them, sadly... So if you have to make one yourself:
CODE: SELECT ALL
|X * X| |1 * 2|
|X X X| |3 4 5|
|X X X| |6 7 8|
The * marks the spot of the dummy pin, X marks the spot of a real pin. In the right image the pins are numbered, below are their purposes. This illustration shows the connector in the car when looking at it from the front.
1 = electr. antenna
2 = earth
3 = 12V switched (ignition on)
4 = positive (+) right front speaker
5 = negative (-) right front speaker
6 = 12V permanent
7 = positive (+) left front speaker
8 = negative (-) left front speaker
Hope this helps (and that it is correct).
copied from an old post of coyote
if you have a different connector ie 2 X 7 or 2x8 then post up and I will see what i can find
CODE: SELECT ALL
|X * X| |1 * 2|
|X X X| |3 4 5|
|X X X| |6 7 8|
1 = electr. antenna
2 = earth
6 = 12V permanent
I have sr-701 with connector 2x7 and I don't know how to connect it, Jim can you help me ?
480S B20F 94' Paris Blue Metallic
480 Collection 158/480 B20F 95' Drak Green Metallic
480 Turbo 92' 234 White
744 USA Turbo, 245 USA D24TIC++, 854 T-5R, 245 Hearse, V70II D5 Polestar, C70 I Cabrio, 440 88' B20F, V70I 2.5T Heico
