I've just bought an '87 ES and it has this great radio fitted. The information on the main club site isn't quite right as it stated two outputs. It has 4 as it has fader control from front to rear.
What I am most interested in is the two connectors on the rear which I assume are to connect an amplifier and maybe an equaliser. They look like DIN plugs/sockets. I am hoping that if I can find the manual I can work out how to hack in a DAB radio but keep this very cool looking head unit in and use an external amplifier too.
It sounds surprisingly good.
So:
1) Does anyone have a manual for it?
2) Does anyone know about the DIN connections?
3) Does anyone know who manufactured this? It says made in Japan on it. If I can work out who made it, their equipment is probably compatible with this.
Volvo CR-4025 Information Required
Re: Volvo CR-4025 Information Required
http://www.analogalley.com/m_fisher.htm
its a fisher brand and heres a link to a site which sells manuals etc...
hope it helps.
well I am assuming its the same thing you need to do an images search and cross check it with your radio.
hope it helps.
- 480s partner
Mine had a paper sticker on top, somewhat faded but I remember clearly that it had Panasonic written on it.
I'm afraid you can only get sound from 4 speakers if you connect an amplifier, the radio itself only outputs 2.
Yes, the connectors on the back are for an amplifier and equaliser but I have no clue about the pinouts.
Yes 480s partner is right and I am wrong !!!
Thank you so much for the information. I will try and get a vintage Panasonic amp on eBay and see if it will talk to the head unit.
