do the front component speakers have a crossover box?
timrosser
Post by timrosser » Wed Jan 18, 2012 8:40 pm
do the front component speakers have a crossover box? If so where is it, in the door or the dashboard?
Tim
swital
Re: do the front component speakers have a crossover box?
Post by swital » Wed Jan 18, 2012 10:18 pm
volvo don't mount a crossover.
480S B20F 94' Paris Blue Metallic
480 Collection 158/480 B20F 95' Drak Green Metallic
480 Turbo 92' 234 White
744 USA Turbo, 245 USA D24TIC++, 854 T-5R, 245 Hearse, V70II D5 Polestar, C70 I Cabrio, 440 88' B20F, V70I 2.5T Heico
480s partner
Post by 480s partner » Fri Jan 20, 2012 10:38 am
The original woofers mounted on the front doors had an extra pair of pins (+ and -) used to add tweaters, located near the door handles. I believe it was a small capacitor inside the tweaters that worked as a passive-crossover making it possible the two speakers connection without changing the overall impedance and preventing the built-in amplifier of the radios from blowing up in smoke.
suddy
Post by suddy » Fri Jan 20, 2012 12:36 pm
Those standard tweeters are rubbish though... I've got a box full at home and found out that only 2 of them work...
1995 480 S 2.0 220,000 Miles
480s partner
Post by 480s partner » Fri Jan 20, 2012 7:25 pm
Have you tried replacing the capacitor on (some of) the ones that don't work?
There is a catch however, the capacitors are "special" (i.e. non-polarized electrolytic capacitors) and unless the same type is used the regular ones won't last much.
I was told this was a common mistake (yet a flagrant error) made by the supplier of the tweaters to volvo during early years leading to batches and batches of tweaters being installed in cars and failing prematurely.
Perhaps that is why the idea they are good quality never caught on.
But of course it is possible that some of them are already in a condition beyond any help.
timrosser
Post by timrosser » Tue Jan 24, 2012 5:30 pm
Right, so if you wanted to upgrade the speakers you would have to go for a full component set, as any replacement for the woofer would lack the extra +/- pins to link up the tweeter & any attempt to replace the tweeter with a more modern one which uses a crossover would probably work badly at best?
T
timrosser
Post by timrosser » Tue Jan 24, 2012 5:52 pm
...or if I put a crossover in the line before the woofer, I could split the wiring like normal & link directly to the standard tweeter & a replacement woofer? (OK I admit I'm a bit scared about getting at the tweeter!)
480s partner
Post by 480s partner » Tue Jan 24, 2012 6:38 pm
timrosser wrote:Right, so if you wanted to upgrade the speakers you would have to go for a full component set, as any replacement for the woofer would lack the extra +/- pins to link up the tweeter & any attempt to replace the tweeter with a more modern one which uses a crossover would probably work badly at best?
T
I agree.
480s partner
Post by 480s partner » Tue Jan 24, 2012 6:50 pm
timrosser wrote:...or if I put a crossover in the line before the woofer, I could split the wiring like normal & link directly to the standard tweeter & a replacement woofer? (OK I admit I'm a bit scared about getting at the tweeter!)
In that case I wouldn't recommend the use of the standard tweater!
The original installation was configured the way it was because the components were made in way that keeps impedance balanced and acceptable by the radios units of the time. Changing them individually without taking into account the properties of the other elements can disrupt the balance and cause damage, unless calculation and testing is made before.
timrosser
Post by timrosser » Tue Jan 24, 2012 8:41 pm
OK, thats a big help! Thanks again
