Cable routing for Amp
T850
Post by T850 » Mon Feb 21, 2011 10:47 am
Hello,
Been reading through your pages for quite some time, thanks a lot for all the useful information within this forum :)
I am currently restoring a smoke grey 480 Turbo to roadworthy condition (well to be honest, it is already more than roadworthy, but having owned a 480 Turbo before, I'd like to address as many points as possible before using it in daily traffic) and one of the things that had to be re-done was the sound system.
The previous owner was a ... is clot the right word? cut off all the tweeter cables, the original speaker connectors, used wire clamps in a lot of wtf-are-they-doing-there-places and so on.
I need to add a separate amp to the new setup, since the radio I will be using (old Clarion unit) doesn't come with an internal amp. My problem is:
This ist a Turbo. With AC. From 1990 (ABS MK2). I could not find any free rubber seals to route the power cable through the firewall, they are all in use by the AC lines etc, the cable looms that enter through the screw-on caps near the windshield are packed full, can't squeeze in a 10²mm there either.
Do you have any recommendation where I might try to route a cable inside so that it is well protected and won't act as an entry point for water?
(LHD car, I'm from the continent ^^ )
Oh, and any advice on how to route new speaker cables inside the doors? Will have to do that, too sadly, the old ones seem to be a bit messed up (and quite thin).
Thanks in advance,
Tobias
(P.S.: My nick comes from owning a 855 T5 ^^ )
Captain Slow
Re: Cable routing for Amp
Post by Captain Slow » Mon Feb 21, 2011 9:42 pm
The previous owner of my car (''esta'' on here) fed (i think) a power cable for her sub through the relay box, just beneth the windsreen..
Previously....
T850
Post by T850 » Tue Feb 22, 2011 7:14 am
Thanks a lot,
that's what I was thinking of too, since that is the way I handled it on my 855. The difference is that the 850 has a higher box with a shallow lid, so you can route the cable trough the side of the box, whereas on our cars the lid is the thing which you have to cut into... I still want to keep it 100% watertight though, it's gonna be tricky :)
Captain Slow
Post by Captain Slow » Tue Feb 22, 2011 10:36 am
My lid isnt drilled, the cable is just passed through between lid and the seal, tis not leaking at all. Thankfully.
Previously....
T850
Post by T850 » Tue Mar 01, 2011 7:58 pm
Just wanted to say thanks - got it figured out :)
Behind the darn ABS MK2 unit there was a tiny little unused breakthrough in the firewall - the last unused hole left :)
I was able to route the powe cable that way and it's working fine :)
timrosser
Post by timrosser » Mon Mar 14, 2011 9:56 pm
Can I ask for a few pointers on the relay box? IS that behind the fuses. Any help much appreciated here!
Captain Slow
Post by Captain Slow » Tue Mar 15, 2011 9:55 am
timrosser wrote:Can I ask for a few pointers on the relay box? IS that behind the fuses. Any help much appreciated here!
Essentially yes, but you access by opening the bonnet, its the triangular lid thats on the drivers side (for RHD cars...I also have the odd feeling that the early models had them somewhere else?)
Previously....
timrosser
Post by timrosser » Wed Mar 16, 2011 4:13 pm
Brilliant, I know that box, I was just cleaning grime out of the little rubber gutter that sits in front of it, this sounds like a plausible job ;-) If I fed the power lines into the cabin from the box, any idea where they come out, do they just drop into the driver footwell?
Thanks again
Captain Slow
Post by Captain Slow » Wed Mar 16, 2011 4:18 pm
timrosser wrote: If I fed the power lines into the cabin from the box, any idea where they come out, do they just drop into the driver footwell?
Somewhere in the plastic above it yes!
Previously....
timrosser
Post by timrosser » Fri Mar 25, 2011 5:53 pm
Hi Captain slow- what do u think the chances are of running a sub of the heated seats electrics? Would save having to do much in the way of wiring?
Best
Captain Slow
Post by Captain Slow » Fri Mar 25, 2011 6:43 pm
I think the heated seats can power everything, I use them to power the alternator ;)
But really, I havent a clue! it was Esta (the previous owner) who did all the fiddling with the sound system on mine, then removed it all-which is also ok with me!
Previously....
