New head unit but no info center bugger
hi all hope you are all well and happy just fitted a new head unit had to cut and join wires as i could not find a iso connector had some dim thing. But now the info center is dead nothing on it any idears how i did this or how to fix it any tips very welcome. stay safe everyone dan.
Do a search on info centre theres tons of stuff on here about them.
quote....
The radio + info centre + cigar lighter + glove box light + boot light + keyhole lights ... etc are all on the same circuit! Did you have the problem with all of them ... and if so ... have your managed to fix them all?
another quote...
I just had this with mine, fixed it by accident the other day
Theres a wire behind the radio (think it's grey with a red stripe, not sure), it switches on and off with the ignition, I needed a switched live wire for my radio so I used this one and my ic started working again
Looks like theres a problem with that wire on mine though, the ic turned off earlier on today and my radio went off with it, only for a couple of minutes though, was fine for the rest of the time
Failing that check the wiring on the back of the alternator, it's earthed there
took all of 60 seconds on search
quote....
another quote...
