Evening all, I'd like to put an amp in the boot of my 480, using quite a large power cable, just wanted to ask what the best route is? I've done it before through the rubber bit where the door cables run though, but there must be a better/tidier way?
Cheers,
Robert
Best route for Amp power cable?
I've done this in two different ways ont both 480 i've owned.
In the '88 version i had no airco. I put the wire coming from the battery through one of the plugs that are in the holes through which aircon pipes usually run. It comes out from under the dash ssomewhere and from there i put it under the carpet in the door sill to the back.
In my other one, which does have airco I used the way u already described, through the doors.
Both times i drew ground from trhe body somewhere in the back. Guess anywhere will do as long as you have direct contact to the body.
GR jamooga
GR jamooga
shit happens, all of the time and all over the world.
1983 vw beetle (brazilian with chopped roof)
1973 vw beetle (real german one)
1993 renault 19 piece o shit car
1988 480 es
1993 480 s
1988 480 es
1993 480 s
- esta
Mine has AC, and its gone from the battery, up the side of the bonnet, under the seal across from the pass to drivers, through the fuse box, under the carpet/tread plates all the way to the back of the car, where it peeps out again and meets the rest of my audio equipment
HAVE: Jaguar XJ40 4l Sov
www.projectjaguar.co.uk
- SMOOTH 480
punch a hole in the gromet like this ..............
then i run the power cable into a distribution block then down the left hand side under the sill covers that hold the carpet in the signal cables (rca) down the right hand side again under sill covers ..
always run the power and signal cable (rca) on seperate sides of the car or you can get static discharge interfering with the signal
Hope this helps mate
Smooth
Smooth
1985 celicasupra ( Project )
member 3285
member 3285
