1) Does anyone have any spare clips that the large grey inside panel hangs in at the bottom, because I broke one and am probably looking at breaking a few more :p
2) How do you get the bit around the large bottom speaker off? I'm just a little scared of snapping stuff by forcing it. That area is the only bit I couldn't get off and so I had that grey panel hanging on the inside of the door.
3) I left the plastic films intact, but if I take it off, will it stick again, is there replacement to be had somewhere, or is it ok without any? I would think maybe it'll get a bit draftier or something?
4) The key I bought was stuck inside the lock. And I do mean stuck, as in I couldn't remove it, or turn it in the lock. Is that because of disconnected electrics, or did I get a broken lock?
5) Because of the way it looks, I just assumed the electrics for central locking and alarm are just "plug and play". Fill in the blanks in my knowledge please if there is anything else I should know before starting attempt #2.
Thanks for any info and help
![Smile :)](./images/smilies/icon_smile.gif)
