Hi everyone,
Hope my 480 is, from now on, as dry as the nevada desert I have loosened the left hinge from the rear window, put liquid gasket wherever I thought there was the possibility of water entering the vehicle, and tightened everything again. Please, let it rain PLENTY!
I am sure it was the hinge as the rubber seal on the inside of the hinge was soaked Also the floormat in the trunk was wetter than a sponge when washing my car
Well, let's see if this does the trick then.
Finally solved? Sealed the rear-window hinges...
- coyote1980
- Volvo 480 Club Europe CREW
- volvofox
donot wait for rain, get a garden hose and lock your selves in the car.
It can also be water leaking allong the much discussed roof rubber (the roof isn't welded! )running from front to rear window.., this water can also get in the car via the holes you describe.
well keep us informed...
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- coyote1980
- coyote1980
