srs on 94
srs on 94
i have just got my self new ish 480
94
it has air bag and srs i have a question on the srs seat belts the passanger side seems to be locked or is lower then the drivers side i have read in the owners book that you can lock the pre tensioner or some thing but with the drivers being unlocked dose that mean it has been used or can i reset it ?
94
hi
both mine are the same. your pre tensioners have fired at some stage, my drivers one fired while ive had the car. I belive they are big expensive so ive not done anything with them.
ste
ste
Car 1 = 94 Red GT - Aircon - Leather - Leaky Boot (but happy owner) - 68k
Car 2 = 90 Black ES Turbo - been to the moon and back!
Car 3 = 96 V40 2.0SE - The family wagon
http://img7.photobucket.com/albums/v18/s.w.blackwell/
- levensnevel
For what it is worth I think you've landed yourself with a problem in the safety area.
I'm not that technical but common sense tells me that if one of your pretensioners 'has fired' your car was involved in an accident.
A proper repair should have included replacement of the 'used ' pretensioner as they form an integral part of all safety precautions in your cheese wedge.
I would suggest that you get it sorted asap.
Niets of niemand zegt dat het echt moet
En toch, of juist daarom,wil je het beleven....
Gammal kärlek rostar aldrig!
Sweet memories
at this moment a Toyota Prius editione Tech MY2008 - 203K km+4K km
- Ben Harris
I know it says "up to '93", but this extract from VADIS may be relevant:
Ben.Seat belt pre–tensioners (up to 1993 models only)
The seat belt pre–tensioners contain a small explosive charge. In this charge there is an igniter which is detonated by a signal from the crash sensor.
This causes a cable, which is attached to the inertia reel unit, to be retracted. The seat belt is therefore tightened before the body of the occupant can be ejected forwards by the energy of the collision. However, the force generated by the explosive charge is not sufficient to pull the occupant back into the seat during a crash.
The seat belt pre–tensioners have a one–off operation, so after a collision in which they have been deployed they must be renewed.
