srs on 94
jamwor007
srs on 94
Post by jamwor007 » Wed Dec 24, 2003 8:20 pm
i have just got my self new ish 480
94
it has air bag and srs i have a question on the srs seat belts the passanger side seems to be locked or is lower then the drivers side i have read in the owners book that you can lock the pre tensioner or some thing but with the drivers being unlocked dose that mean it has been used or can i reset it ?
:hopping:
red480gt
Post by red480gt » Wed Dec 24, 2003 8:22 pm
hi
both mine are the same. your pre tensioners have fired at some stage, my drivers one fired while ive had the car. I belive they are big expensive so ive not done anything with them.
ste
Car 1 = 94 Red GT - Aircon - Leather - Leaky Boot (but happy owner) - 68k
Car 2 = 90 Black ES Turbo - been to the moon and back!
Car 3 = 96 V40 2.0SE - The family wagon
http://img7.photobucket.com/albums/v18/s.w.blackwell/
levensnevel
480 Expert
Post by levensnevel » Wed Dec 24, 2003 9:27 pm
For what it is worth I think you've landed yourself with a problem in the safety area.
I'm not that technical but common sense tells me that if one of your pretensioners 'has fired' your car was involved in an accident.
A proper repair should have included replacement of the 'used ' pretensioner as they form an integral part of all safety precautions in your cheese wedge.
I would suggest that you get it sorted asap.
Niets of niemand zegt dat het echt moet
En toch, of juist daarom,wil je het beleven....
Gammal kärlek rostar aldrig!
Sweet memories
at this moment a Toyota Prius editione Tech MY2008 - 203K km+4K km
jamwor007
Post by jamwor007 » Wed Dec 24, 2003 9:40 pm
but it dose say in the book that you can release it and reset it thats why was unsure of what to do ?
Ben Harris
Post by Ben Harris » Thu Dec 25, 2003 1:32 am
I know it says "up to '93", but this extract from VADIS may be relevant:
Seat belt pre–tensioners (up to 1993 models only)
The seat belt pre–tensioners contain a small explosive charge. In this charge there is an igniter which is detonated by a signal from the crash sensor.
This causes a cable, which is attached to the inertia reel unit, to be retracted. The seat belt is therefore tightened before the body of the occupant can be ejected forwards by the energy of the collision. However, the force generated by the explosive charge is not sufficient to pull the occupant back into the seat during a crash.
The seat belt pre–tensioners have a one–off operation, so after a collision in which they have been deployed they must be renewed.
Ben.
jamwor007
1994
Post by jamwor007 » Thu Dec 25, 2003 8:02 am
my car is M 1994 so will that make any diffrence to the srs system ? can it be reset >? do you knwo where i can get the vadis copy from ?
Daniel480
Post by Daniel480 » Thu Dec 25, 2003 11:39 am
Hi,
don´t be afraid that your cars had an accident when the pre-tensioners have been fired.
It´s a known problem that the tensioners fire by their selves !
Very expensive joke :badmood:
Regards.
Daniel
jamwor007
Post by jamwor007 » Thu Dec 25, 2003 11:41 am
so is there a way to reset it or is it nor worth it just for future reference :)
Daniel480
Post by Daniel480 » Thu Dec 25, 2003 11:52 am
Hi,
they must be replaced ! I don´t know what things the MOT is looking after,but in Germany the car fails to get TÜV(MOT), when the tensioners are fired and not been replaced!
Regards.
Daniel
jamwor007
Post by jamwor007 » Thu Dec 25, 2003 11:57 am
you have any idea how much they cost to reset dont think they need doing here in uk for mot so will have IT LOOKED AT
Daniel480
Post by Daniel480 » Thu Dec 25, 2003 1:58 pm
Sorry, no real idea about the costs !
Should be around 200-300 € ! for a new tensioner :cry:
Regards.
Daniel
