Headlight bulb turn knob
I want to be a dashboard hero How do I remove the Headlight bulb turn knob?
- dragon
- Volvo 480 Club Europe CREW
/me waits for Martin's next post saying the knob came off, but the knob mech stayed in
Gaz Wilson
Gaz Wilson
- daz480gt
hi martin
after reading your post, i got in my gt and pulled the light/knob switch out
it was tight, but easy really, there's about 6+ spade connectors on the back of the switch
so it seems tight until it pops.
i'm glad i did have a look martin
i found i had flat battery, the light in the boot had stopped on.
i have 2 shut the boot glass really hard 2 make it go out
the boot release knob seems tight, maybe some adjustment is needed
keep pulling your knob, and it will pop
cheers
cheers
cheers all
http://img4.photobucket.com/albums/0603/dazbolt/?&action=logout
- coyote1980
Re: Headlight bulb turn knob
I wouldn't simply pull it, as the others say. My car has a very tight fit between the frame that goes around the whole dashboard and the turn knob and I don't think my knob would come out without anything breaking. I suggest you remove the little panel with the switches for front+rear foglights and rear demist, loosen the screws holding the frame behind that panel, the screw on the underside of the frame to the left of the steering wheel, the screw on the underside immediately above the steering wheel and perhaps the screw on the underside of the frame to the right of the steering wheel. Then you can pop the knob free of the frame first by flexing the frame away from the dash before you pull the switch straight out. You only need a gap of 1-2 centimeters or so.martinholmesuk wrote:I want to be a dashboard hero How do I remove the Headlight bulb turn knob?
