Leather door trim
Leather door trim
Hello!
My leather trim which is on the doors keeps falling out of the holes.
I keep putting it back but the holes just get bigger so it all falls down again.
I need a way to keep them up. Ideas?
- dragon
- Volvo 480 Club Europe CREW
Is your car in some way linked to mine? You heater matrix dies, so does mine, your door trim starts falling out, so has mine - my holes are also too large for the threaded clip, but I also have one broken trim clip - for the non broken one I was just going to pop insulating tape to make the threaded bit a tad bigger so it'd hold...
Gaz Wilson
Gaz Wilson
- dragon
No I had my altenator replaced a year and a half ago ...
My drivers door has lost it's "staying open" ability, and the speaker has just stopped working too...
Good job I'm going to replace the bloody doors...
Gaz Wilson
Gaz Wilson
- dragon
A taped Klit, eh? No, let's not go there...
Gaz Wilson
Gaz Wilson
I had the same problem, first i tried to solve by using velcro but found out there was a small gap because the velcro is thick.
Then i got the final solution, use the butyl kit sold by the dealer on a roll. (the same partnumber as the stuff used to seal the backlights.)
Just put a blob here and there and push tight into position. Never been loose again and you can still remove the cover when required.
I also used it on the rear speaker covers, because my bass blew them off and that also survives.
Regards, Renter
Regards, Renter
Volvo 480 2.0 ES, 1995, Paris Blue
- volvofox
now hold on, i am sugesting no tape at all. You see klit everywhere. also on the mats in out car. (maybe i am not translating right?)
like renter i use a sealant as glue. its perfect, noise absorbing and can move a lot before cracking or loosening : Bathroom silecone
i feel rooling tape or something around the "plugs" is real crap. (sorry)
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- kirsty_2003
Hi Kirsty,
This is one we covered early this year.
If you look at the bottom of your door card. The bit with the handle and pocket on. You will see some plastic clips that the card sits on. It is fairly straightforward to lift the card off these. Then spray the clips with WD40 and push the card back on. Voila! silent door.
Regards
Chris
Regards
Chris
dragon wrote:My drivers door has lost it's "staying open" ability.
I had that to, so i went to the Volvodealer and they welded the articulation to the door again and it was fixed
cost me 1 workinghour tough......
Volvo 480 GT-Turbo 1995 ~ 321 current
Volvo 480 Turbo 1994 ~ 305 got totalled
Volvo 480 GT-Turbo 1994 ~ 323 sold
Volvo 480 Turbo 1993 ~ 305 sold
- coyote1980
