Waxoyling ports??
Waxoyling ports??
I want to waxoyl the inside of my front/rear wings and the sills. Anyone know the best places to get in and spray the stuff?
Is it worth drilling access holes and then blocking them off?
John
John
- volvofox
whats waxoil ?
is it the same as tektile for holow spaces ? them whit big spraycans with the long thin tube and the special nozzle ?
good stuff this tektiel. it made my other car live to be 30, whithout any big rust.
I saw i could see in the frame work as i took away and replaced the steel bumper part.
the stuf i used drives away condens, instead of sealing it in. its very very penetrating. It will preserve your lungs long after you die, but its real good stuff.
small disadvantage : your car smells like a beaver for months.
luck
JPF
luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- Ben Harris
Waxoyl (appear to) make all kinds of car car products, but the one most commonly known (and often just called by their company name), I would imagine it this. At least, that's the only product that I was aware of, before looking at their website!
Ben.
Ben.
Hi,
I believe you can choose between tectyl and wax for internal corrosion prevention.
Wax is generally used if a car has been waxed before from factory because its no use using tectyl on a car that has been treated with wax. Wont hold very well.
I used tectyl products, again two types: for internal use, very runny thin stuff that creeps everywere that you can apply with a long tube to reach internals.
The other stuff is the thicker black stuff used for external plating, wishbones etc. Applied as spray paint.
For a 480 i would go for tectyl product not for wax products.
When internal of car was stripped i used the openings inside the car, the stuff ran out from the outside under the car. With the car on the lift you can reach every nook and cranny with the runny tectyl and the tubing.
For the bottom i used the thicker stuff.
Dont forget wheel arches, remove the plastic. The front and back bumper carrier. (is a bitch to remove, but they were rusty as hell.)
I even did the doors and the inside of the roof, specially the structure at the front window, had some rust there. Also did the wishbones and all other steel under the car.
I love tectyl, i think i used about 6 big spray cans in total.
Regards, Renter
Regards, Renter
Volvo 480 2.0 ES, 1995, Paris Blue
On my old fiesta (old but immaculate when I gave it to my sister) I used the Waxoyl you get in a steel can, not the aerosol stuff. I then kept the stuff in the direct sun for a couple of hours to make nice and runny. To apply it I used a pressurised Plant sprayer, it went on like a dream..I removed plugs and sprayed it in, waiting until I couyld see Waxoyl running out the drain holes before moving on. I would say his is a very good way of preserving your car. The other main advantage is that by the time you have finished (if you are being thorough enough) you will have a good idea of the condition of all of your car and be more familiar with areas that require more attention.
I used the clear waxoyl for the fiesta, not sure about the black stuff, I know that you can wash it off any paint work if needed, I even did the underside iof the bonnet, the boot interior...yes it does smell, but not for very long.
But I would not even entertain the idea of doing it this time of the year, unless you have a heated garage and you do not mind wrecking the floor...which is another point....COVER your driveway as Waxoyl will permanently mark the floor.
Worth using Google to search on this, there is a guiy that does this for 4x4 cars, he lists his method from start to finish and they are worth following...pressure wash underside of car first, arches, sills sides, front and rear.
If you talk to many classic car owners, they all use Waxoyl to preserve body work.
Black 480ES J Plate
http://img5.photobucket.com/albums/v14/Hereagain/
Steve
Cambs
Steve
Cambs
- dragon
- Volvo 480 Club Europe CREW
Perhaps we could get a list of interested parties and buy in bulk and then get together one weekend for a mass-preservation party?
Gaz Wilson
Gaz Wilson
- Murf
Ziebart
i've got a reciept from Ziebart for my Mk2 Escort which was treated when it was brand new, it seems to have worked as its still not bad after nearly 27 years!! I think Ziebart used much the same stuff except they were more thorough, drilling holes in inacessable pleces to spray it in.
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
- dragon
It is a very good excuse for a party/meeting, but in the end I am not particularly bothered if we do it ourselves or have some professional do it, as long as we get a good deal for a bulk/block purchase or booking - Steve definately make inroads with this guy and see what kind of prices you can get. We can then see how much it would cost to buy the stuff and hire the kit to do it ourselves and see which we all fancy?
Gaz Wilson
Gaz Wilson
- volvofox
I would use tectyl for several reasons.
1 its a more modern product and will fit better in the existing inner anti corrosion of volvo.
2 it doesn't seal in moist like wax, but it " pushes water away"
3 the 600 ml spraycan is real good to handle. you don't need a summers day, a special sprayer or a compressor.
4 i have real good experience with this product. It made my other car turn 30 years old
and I can go on....
see around this page
http://www.valvolineeurope.com/tectyl/e ... s1.html#ml:
and I can go on....
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- dragon
One drawback, VF, I don't think it's available in this country and importing may prove prohibitively expensive... (I haven't looked though, but I've never heard of it)
Gaz Wilson
Gaz Wilson
