Hey all,
I have a couple of problems on me 480es,
First one and most annoyin is that the drivers door doesnt stay open does anyone know what could cause it? and how i can rectify the problem cos its startin to annoy me!
also just lately the passenger window needs a little help to make it open could this be the electric window motor on its way out?
Hope someone can help
Thanks Matt
Doors wont stay open
I might b dead in 50 years so might aswell enjoy the short time that i'm here.
- volvofox
take of the door panels. You will find a big odd twisted spring, which gets a grip on the opener rod. replace this one. If your problem is serious, the braket that holds the spring has been broken out of the bodywork. this is a known problem. Have it welded. (this is not visible from the outside/front)
I feel its a bit normal, the doors fall back. you can get used to.... but.. take care of the ladies feet and leggs.
But than again... If their not fast enough, they don't belong in this car....
luck
JPF
PS : grease the window guiders and the mecannics behind the panel. Maybe ajust the window guide rails.
luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
I had the bracket shear off from the inside of the door, found that it had already been welded once, my dad managed to bolt it back together and it's been fine since.
1996 Mini Classic 1275.
- Ettore Bugatti
- midnight rambler
