bukky
Post
by bukky » Sat Apr 16, 2005 2:49 pm
Please, which tank capacity, 48 or 61 litres comes with the volvo 480, 1991, H reg turbo automatic?
Thanks for you usual co-operation,
Bukky
rpruen
Post
by rpruen » Sun Apr 17, 2005 12:06 am
Press the reset button on the infocenter while turning on the ignition, then turn the infocenter to fuel. It should tell you the fuel tank capacity +- a bit.
Hope that helps
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
chris1roll
Post
by chris1roll » Sun Apr 17, 2005 10:06 am
H plate was a changover year, Best way to tell is either as Richard says, fill the tank then hold in the button etc, or run it till empty then refill to the brim and the petrol pump will tell you how much you have put in.
2001 V70 XC 2.5T
1989 744 GL Auto
coyote1980
- Volvo 480 Club Europe CREW
Post
by coyote1980 » Sun Apr 17, 2005 3:37 pm
Use the VIN reader on the website to determine modelyear, that way we know if the modelyear is 1991 or 1992...
Daniël Wilten
Volvo 480 Turbo Collection 1995 Dark Green Metallic
Club Europe chairman/webmaster/forum admin
mogge
Post
by mogge » Sun Apr 24, 2005 7:08 am
Hi!
From chassie nr 567600 the updated ny tank came,
/Jonas
Engineer
