Heater Matrix
- dragon
- Volvo 480 Club Europe CREW
Heater Matrix
OK, the result of today's Volvo trip is that the heater matrix IS leaking somewhere, just not into the cabin (possibly it has a leak at the top so it leaks vapour and not liquid?) - I own a turbo. How much (in hours for a good mechanic) is involved in replacing it? Volvo have quoted me silly money for fitting one, plus a few other bits and bobs.
On the same theme, who has any garages to recommend in the Sheffield/Barnsley/Wakefield area, as I think it MUST be cheaper to get it done that way...
Gaz Wilson
Gaz Wilson
- dragon
for fitting all the stuff mentioned in my other thread... about £660 !
Gaz Wilson
Gaz Wilson
- dragon
a) no time (and it needs doing quickly)
b) probably wont have the right tools
c) don't have enough info about how it comes out (like I'm trusting Haynes on this)
d) I have a turbo (which seemingly makes it a LOT harder)
Gaz Wilson
Gaz Wilson
Heater matrix
Alright Gaz,
I live near Worksop and use / swear by my Volvo specialist.
South Carlton Motors, 01909 730386.
50 High Road, Carlton in Lindrick, a few miles north of Worksop, and the main time served mechanic is Simon Hopkinson.
Good luck.
Gedda
Good luck.
Gedda
2 Marina Coupe's, 2 Ford Capri's, 1 Austin Maestro, 1 Polo, 1 Volvo 440, 1 Volvo 850, and at last my '95 Celebration.
- dragon
Yeah, I used to go there when I lived in Worksop - might go back there if I cant find anything closer
Cheers for the phone number
Gaz Wilson
Gaz Wilson
changing heatermatrix
Hi Dragon
It is a simple straight foprward job for once.
Even on the turbo.
If you are quick and experienced a little less than 2 hours
If you are not an afternoon.
Tools and material needed
-simple screwdrivers for trhe centerconsole and the jubileeclips
-a heatermatrix
-coolingfluid
-good quality textile tape about 1" widht (like the hockeyers use on their
stick)
- eventually new good quality jubileeclips
This is also a good time to think of renewing the hoses to the heatermatix.
Work involved
1- undo the 2 jubileeclips in the motorcompartment and take the two
hoses off
2- drain cooling fluid if neccesary
3- remove the centerconsole completely (that is the console where the
handbrake and gearlever is)
4- remove the sides left and right of the centerconsole under the
dashboard
5- take away the two plastic "tubes" that direct the air from the heater to
under the car these tubes are under the heater between the heater and
the central tunnel.
6- remove the screws that hold the underside of the heater (If i remember
correctly 3 left and 3 right)
7- pull out the heatermatrix
installing a new one is working in te reverse way but be carfull wen placing the "new" matrix it is a bit fiddly.
Good luck
gerrsvolvo
outside
Even on the turbo.
-a heatermatrix
-coolingfluid
stick)
Work involved
hoses off
dashboard
the central tunnel.
Good luck
gerrsvolvo
outside
- volvofox
Yes dragon. You think to much. Stop thinking and act.
Yust start.
same with me I read all the fuss about sheared loose M8 bolts of the pulverized rearbumper frame, and I did not start this job but as fore yesterday (today my car got APK) I knew for two years this had to be done Luckyly they did not see this last time.
Afterall, this was an easyjob, with assistance from mr. Kev'sturbo it was done in all ease in an afternoon. Now what whas I afraid of ???? I sprayed the bolts in with WD 40 a few days before, and all went well.
Moral of this : Information can be usefull, but also countereffective, because you prejudged and afraid.
safe yourselves a lot of money and learn something.
Luck
JPF
Yust start.
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- dragon
gerrsvolvo - thanks for the encouragement and advice - I wish I could do it, but I am on call this week for work, so won't be able to, and it can't wait over a week to get sorted.
Volvofox: I know - but I am paid to think before I act, so yeah it's a drag, but I do like to be clear on stuff before I start
As it happens, I think I have found a freindly independant Volvo specialist nearby - he certainly knew about the 480 and we had a good chat. I think it's going there to have it fixed...
Gaz Wilson
Gaz Wilson
Hi Chriskay
I forgot to explauin that.
Sorry.
This is an old thing and mostly forgotten in teh garages.
It is to protect the hose on the place wher the jubileecip is.
If the hoses get older the chaper clips with more or less
sharp edges start to cut in the hose when these cliops are mounted
direct on the rubber of teh hose.
And you should be the first one who cannot find the leak in the coolingsystem because it is hidden by the jubileeclip
until the hose shares off completely with all the expensive effects.
If you see the older DAF 55 you see that DAF did the this protection
on his hoses. And I have never had a shaered off hose in teh region off the clip.
Good LUCK
Gerrsvolvo
Sorry.
Good LUCK
Gerrsvolvo
Ho volvofox
I once long ago had one 55 coupe theh first type.
It had an LPG conversion on it I drove it aproxematly 80 000KM a year
It had one real drawback I needed ca. every 60 000KM a new or reconditioned startermotor.
It was tuned and one engine was destroyed by it by trowung a conrod trough the block near Kerpen in Germany.
I died after a ''severe'' accident.
Gerrsvolvo
Gerrsvolvo
- dragon
Well, I had mine fixed today - in the week since I took the carpets up and told you lot it was clean and dry, the leak got worse and it has wetted one of the footwells - the garage have replaced the matrix and dried it up as best possible, but I think I'll spend a few hours at the weekend with a hair dryer in the car paking absolutely sure evrything is as dry as possible. Came home from garage (about 3 miles) with heater on half -the windows cleared within minutes and by the time I got to where I was going the car was roasting hot inside, so they definately replaced it - Also had the 2 front ball joints renewed and a new wheel bearing (front) fitted - the total cost was just slightly more than a third of the (minimum) price Volvo were quoting. Plus the garage know the cars (the owner has a 460) and they are dead friendly, so I think my car's found a new maintenence home for jobs I can't or won't tackle
Gaz Wilson
Gaz Wilson
- dragon
Did I mention they were cheap as chips? Well OK, not that cheap, but good enough for me £240 for everything mentioned above
Gaz Wilson
Gaz Wilson
