Window goes up...Window goes down...
- MGB_GT
Have a weird problem with Drivers side Electric Window. It can never decide what speed to move at. Sometimes it's reasonably quick poping up and down, other times it's exceedingly slow, especially it using the full closure system from the door lock. However the passenger side is consistant and seems much faster than my old 480. I didn't think the window would be off it's runner because usually that wouldn't cause it to continually change speed, any ideas?
Yepp!
Try to oil it with silicon oil, if its to slow there is high pressure in the lift systems. Thats not good, it have a bad habit of braking then.
Take a look at the window, when lifting, if it "turns" in the guiding system (lower on the side towards the rear) Try to lift it rigth, any change?
/Jonas
/Jonas
Engineer
