My 1995 Celebration is in good condition, everything works (for now) and it drives well. The only problem I have with it is all the bloody annoying noises, rattles and squeaks! I've tightened everything I can but it's no good.
Now I know everyone has this probelm, to a degree, but has anyone out there come up with an ingenious way of making these cars quiet? Any ideas?
Cheers,
Ben[/i]
Noises, rattles, squeaks - is there an answer?
Hi Ben,
On an old thread we went through this in some depth. The majority of the noise comes from the door panel. Obviously other places as well.
It was earlier this year and I had just bought a Turbo and the noise was very annoying. A little research showed that the noise was coming from the clips at the bottom of the door that hold the door panel in place. I sprayed with WD40 and the noise went!
Give it a go.
Regards
Chris
Give it a go.
Regards
Chris
- volvofox
well to the interior, were most people suffer from i don't have any trouble, exept two spots, 1) the beltlocks (metallic "iep" sound)(just grease) and the left upper corner of the major dash. I had have a piece of tough foam wedged between the mirror and the dash, which helped a few years, until it fel between the dash.( I have to make a new one)
I have no door panel noise. This is because i glue them everytime I have opend them with some spots of silecone (volvo480 tool number two, after contactspray) The original plastic click plugs have gone numb. I also put all the connectors wedged in the original door connectorbox
further on there must be some exterior noises, which i don't mind/or got used to.
I am working on noise from the rear exhaust ( suckers from quick fit don't know ater three times to fit their fony exhaust ) I have made a vertical silencer, which i still have to proof (tomorow)
The cheap tyres on the 5 spoke OZ wheels hit the innerbodywork. I simply try to knock back the spots that hit it, but maybe I have to soon find another way. Its not dammaging the tyre.
I wonder what happened to the technic the (japoneese?) developed 15 years or so ago: they simply recorded the noise, and in almost the same instant put the noise in converted (negative puls) way back, leaving silence.....
luck
JPF
luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- dragon
- Volvo 480 Club Europe CREW
We were having a conversation about this very thing the other day... Would be excellent in my car - We didn't know the answer to where this tech went...I wonder what happened to the technic the (japoneese?) developed 15 years or so ago: they simply recorded the noise, and in almost the same instant put the noise in converted (negative puls) way back, leaving silence.....
Gaz Wilson
Gaz Wilson
