My windows mist up.
if you pull the carpet away from the tunnel console on each side, you will see (8 ?) bolt heads that hold the cover (but its on the bottom) on the heater. You can remove this without spilling any coolant. YOu will need to remove the plastic pipes that take air to the rear floor, and a bracket on the passenger side to get it out...... D'oh you have a turbo.... hmm, you may have to move the injection ECU too. Don't know if air con makes this any different.
If it leaks bad you willl see the gooey coolant on the outside of the box before you take the bottom off.
You will be able to see then if it is leaking.
steamy windows
Hi Martin,
I spoke to my trusty volvo specialist yesterday and mentioned your predicament, and unfortunately he reckons that it is your heater matrix which is leaking.
This alone is not too major a job, but having aircon makes it alot harder.
If I was you I would get your baby to a garage you can trust, close your eyes and hand over the readies. Unless you can do it yourself.
Gedda
Gedda
2 Marina Coupe's, 2 Ford Capri's, 1 Austin Maestro, 1 Polo, 1 Volvo 440, 1 Volvo 850, and at last my '95 Celebration.
steaming windows
im not so good in english so i hope that you boys understand it right anyway...id had that problem to..a hole lot of smoke..couldnt se anything so i was forced to drive with the side winddows open the problem was that the heater had gott a little hole because it was old and when the glyckol get into temp it starts to smoke out trough the hole..and you gott it on the flor to and it stinks hope that you have understand me
i,l be back =)
Well that makes sense. my mates got me a smoke machine for my birthday, and it works by heating up a glycol solution, before pumping it through a small hole.
It's just a heater, and a pump... Which is pretty much what a cooling / heating system is...
Very similar stuff to antifreeze. I reckon yo84 has it!
- dragon
- Volvo 480 Club Europe CREW
Think I might try to find a local garage, or at last resort down to Volvo for a look at the problem
Gaz Wilson
Gaz Wilson
- dragon
Is the carpet just pullable? Must have a look at least this far before I consign it to the garage
Gaz Wilson
Gaz Wilson
