Does anyone have some pop up headlight hinges?
Posted: Wed Jul 14, 2021 2:56 pm
by GCooper
It would cost 60 euros with shipping to the UK so I was wondering if anyone here had some they're willing to sell?
Pictures attached
http://imgur.com/a/hoQRyL3
Re: Does anyone have some pop up headlight hinges?
Posted: Wed Jul 14, 2021 3:34 pm
Good to see you again! Hows the GT?
Do you know anyone with a 3D printer? If so you can
print your own
Posted: Wed Jul 14, 2021 3:47 pm
by GCooper
how's the GT
Well, it still drives
Airbag light, both window regulators need replacing, windscreen washer pump and some other stuff.
Should be mostly sorted soon
Posted: Wed Jul 14, 2021 3:51 pm
GCooper wrote: ↑Wed Jul 14, 2021 3:47 pm
Have the regulators snapped? Again you can
3D print a repair kit
If the motors aren't spinning at all, check connections at multi plugs aren't corroded.
Washer pump - For the purpose of MOT, you could swap the front and rear pumps over (rear pump isn't MOT testable).
New pumps aren't expensive though
Posted: Wed Jul 14, 2021 3:55 pm
by GCooper
The right window is completely detached from the regulator and the left gets jammed, I think it's because of a loose cable
Posted: Wed Jul 14, 2021 6:07 pm
by MisterH
GCooper wrote: ↑Wed Jul 14, 2021 3:55 pm
That happened to me once (my fault)
But I was able to fix it by threading the metal wire back round the sprocket, but my fingers did not forgive me for a long time!
Posted: Wed Jul 14, 2021 7:43 pm
by brinkie
Send me your address, a very kind 480 driver who's moving house and needed to get rid of stuff has given me a four of these headlight hinges to share amongst the needy!
Postage won't be Skandix-priced: 6 Euro.
Posted: Thu Jul 15, 2021 6:53 am
by GCooper
MisterH wrote: ↑Wed Jul 14, 2021 6:07 pm
I'll see if I can fix it myself, if not I'll get a new regulator. I haven't looked at the driver side yet, it wasn't a priority because I managed to close it by hand
Posted: Thu Jul 15, 2021 8:17 pm
by Alan 480
Airbag light,
remove bulb, sorted
Posted: Thu Jul 15, 2021 11:00 pm
by GCooper
If I can't fix it before the MOT this is what I'll do
Posted: Wed Sep 15, 2021 7:42 pm
by GCooper
Alan 480 wrote: ↑Thu Jul 15, 2021 8:17 pm
Airbag light,
remove bulb, sorted
This is what I'm going to do, I've also ordered a 1989 steering wheel with no airbag
Posted: Wed Sep 15, 2021 8:03 pm
You realise you’ll need a few more bits?
Upper column and light stalks are needed too
See
Jay K’s post
