Type of bolts/screws
Hi all, my plastic cover for rear hatch/petrol flap is loose. What type of screw/bolts are they that hold it. Have tried taking a picture with phone but it won’t focus! Am hoping they are Allen bolts or Phillips because of access. Don’t want to take seat out if I don’t have to.
Re: Type of bolts/screws
Do you mean the ones that hold on the grey surround which the black lever travels in?
I think these are No. 2 (the usual size) Philips screw heads.
You should be able to get in with a 90-degree screwdriver
I have this set and am pretty sure I got in no problem to the screw heads.
They are 10mm bolts Norm; you can get in with a small ratchet...
Thanks guys.
Good luck Norman.
I'm not saying I think James is wrong, btw - I do think this is one of those things that changed between earlier and later models...
Fiiiiiiiiiiiiiiiiight!
