A/C button nest to gearstick!
MatBat
Post by MatBat » Mon Oct 20, 2003 12:41 pm
My 1992 480ES has a normal style heater panel and a Recirc button and a button with a (*) on it next to the gear stick. Is this usual.
BTW the car does have an A/C compressor before any jokes occur :hopping:
Though it probably needs regassing! :angry: as the air is not cold :( ,but it's cold enough in England anyway :D
1996 Mini Classic 1275.
MatBat
Post by MatBat » Mon Oct 20, 2003 1:35 pm
It gets worse, when I push the button, for the a/c (*) the compressor doesn't engage. I have checked the fuse in the car and the fuse on the relay that one of the wires from the comp. leads too, but they look fine.
:help:
Mat
martinholmesuk
Post by martinholmesuk » Mon Oct 20, 2003 5:16 pm
Mine was warm air until they filled her up! The recirc button uses 10% air from outside so the cold air inside is just made colder while using 10% (warmer) air from outside!
asterix
Post by asterix » Thu Oct 30, 2003 12:43 am
My '91 ES has aircon controls as you describe: it won;t blow cold although I hear the compressor. It may be user error as I have no idea how to operate it, but as the car sat for 6 months before I bought it I think it likely that it needs regassing. No idea how much that'll be thogh, so I suspect I'll leave it until summer!
Happy driving!!
Bruce
'91 ES, cheap but great....
martinholmesuk
Post by martinholmesuk » Thu Oct 30, 2003 8:40 am
Should just need regassing. I had the same problem with my new 480.
MatBat
Post by MatBat » Thu Oct 30, 2003 9:26 am
I can't even get the compressor to engage when I push the a/c button, so I don't know if it needs regassing until I get the unit to work.
:cryhard:
Oh well
It's winter now anyway.
480-Pelle
Post by 480-Pelle » Sat Nov 01, 2003 12:28 am
MatBat wrote:I can't even get the compressor to engage when I push the a/c button, so I don't know if it needs regassing until I get the unit to work.
:cryhard:
Oh well
There is a pressure switch in all AC-systems that stops the compressor from engaging if there isn't enough pressure in the system.
If the compressor doesn't start ( a click and it puts a little load on the engine and the fan also starts ) you most likely need to get the system filled up...
//Pelle
MatBat
Post by MatBat » Sat Nov 01, 2003 10:35 am
Okay, Will try that.
VOLVO480S
Ac / * button
Post by VOLVO480S » Sun Nov 02, 2003 1:24 pm
Does you're car have an automatic gearbox? --> If so, the *-button is meant to skip the first gear and start from the second. This is meant to avoid wheel-spin in slippery conditions.
MatBat
Post by MatBat » Sun Nov 02, 2003 2:04 pm
Manual gearbox :D
volvofox
Post by volvofox » Sun Nov 02, 2003 8:34 pm
is there any chance you have traction control ? I have learned the last "of the mohicans" have em sometimes, since yours is a '92, well, who knows.
Do you have ABS ?
Most likely its combined
Luck
JPF
luck,
JPF
Nomen est Omen
MatBat
Post by MatBat » Sun Nov 02, 2003 11:08 pm
Apparently it has ABS though it doesn't seem to work. I am confident that the button is for the A/C because when pressing it the blower fan (for heater/vents etc.) starts, thus it must be connected to the ventilation system. Also it there is no other button, to engage the compressor, and next to the (*) button there is a recirculate button
Shame would like traction control :D
Though I am using 195/55 Michelins which stick like glue :hopping:
MatBat
Post by MatBat » Sun Nov 02, 2003 11:13 pm
Have heard that the A/C doesn't work below 10C so it could be fine after all! :lol:
Btw in deep dark Sussex it is currently about 6C
