Gas springs for the rear window
So my springs cannot hold the window anymore, but i can't find any replacement specifically for the 480. So does someone know any compatible springs i can use?
1987 Volvo 480 ES (red)
Re: Gas springs for the rear window
They are widely available. However...
My choice would be to send yours (along with the pop up light gas struts which are probably also very weak now) to SGS Engineering. They will recharge yours and if they hold a pressure, send them back. If they don't hold pressure, they'll send you replacements.
https://www.sgs-engineering.com/gas-struts
Handy wee thing to know James...jamescarruthers wrote: ↑Tue Aug 20, 2019 3:12 pmThey are widely available. However...
out of curiosity, I take it a failure of a gas strut can put excess wear on a motor long term?
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
I think the pop-up motor teeth will be under more pressure with a knackered strut when deploying the lights. But then you could argue that they will be under more pressure when retracting with a fully charged strut! So, I don't really know if it will prolong the light motor's life-- more spread the wear out!
I would say that the big issue with depleted struts on the pop-ups is that they bounce around like crazy when you are driving which must annoy other drivers and also yourself on a long journey on the motorway at night. After replacing/regassing the struts, they'll need aligned as the lights will be slightly higher.
SGS don’t recharge them, but they will give you brand new ones of equal length and poundage.
Henry (the green turbo) has a set on the pop ups; they list the tailgate ones in their catalogue and I tried to get them to include the pop ups in there too (after having mine as samples), so they may be there now.
I don't know where everyone stands on the Skandix front but... they say they offer both. Not sure of the going rate over here; weather these are highly priced or not.
http://www.skandix.de/en/spare-parts/bo ... ?f=s240274
Skandix = thieves
They do recharge them as they did two of the four I sent them. Can't remember which two they managed to do though.
I'm going to try to use universal springs for the hatch they should do it just fine.jamescarruthers wrote: ↑Tue Aug 20, 2019 3:12 pmThey are widely available. However...
A word of caution.
I have 1 strut on the hatch the same size as the originals which came from a rover 216 coupe.
Holds the glass great but I recently noticed that when closed it pushes the glass out of line giving a small gap at the rear lamp.
For the hatch and lamps have a look at the body of the strut and you might see a small ridge, this is a by pass. There is no pressure until lifted and when closed the assistance stops.
Something to be aware of.
you can get correct length and poundage units from 'tinternet' I got a pair and were not 'super' expensive, well not into rear-light arenaFox wrote: ↑Tue Aug 20, 2019 10:53 pmI'm going to try to use universal springs for the hatch they should do it just fine.jamescarruthers wrote: ↑Tue Aug 20, 2019 3:12 pmThey are widely available. However...
