Removing front wing
Removing front wing
Post by Martin Mc » Sat May 04, 2019 10:54 pm
Hello folks,
I've trawled the various threads for pictorial insights into getting the front wing off - Glasgow Jim's photobucket 'How To' guide photos are long gone. Suffice it to say I have had a bit of a 'mare trying to get the driver's side wing to budge - all visible bolts removed, most of the wheel arch liner screws and clips out, but it seems like the top of the wing is also held down by the bonnet fastenings. Is that the case, or is it just obvious how it all comes apart once everything is off (inc wheel arch liner)?
Thanks for any tips :)
arthuy
Re: Removing front wing
Post by arthuy » Sun May 05, 2019 11:05 am
There is a long bolt fixed under the bonnet hinge so has to come up to free the wing. Access to the nuts underneath.
Couple of bolts down the door edge and sill can be missed. But when the arch liner is off you can see better.
Post by Alan 480 » Sun May 05, 2019 3:19 pm
and those around front edge of wing (behind back edge of bumper) are 'tricky' if the bumper is still in place.
