Fuel door fixed
frenchfries
Fuel door fixed
Post by frenchfries » Tue May 29, 2018 10:27 am
Hi all
When the fuel door does not open AND before removing half the boot trim, spend a considerable amount of time trying to play with the cable tightener and swear a bit, make sure to check that the problem is not with the metal plate within the door housing (only 2 screws easily removed) :kill:
Re: Fuel door fixed
Post by jifflemon » Tue May 29, 2018 10:54 am
so we won't be getting a "how to " from you anytime soon then? :rofl:
frenchfries
Re: Fuel door fixed
Post by frenchfries » Tue May 29, 2018 1:05 pm
Told you, 2 screws.
Will amend with a picture later :)
frenchfries
Re: Fuel door fixed
Post by frenchfries » Sun Jun 10, 2018 8:54 pm
Here was the culprit. Inside the mechanism is a little metal plate which forces the hinge out when it is unlocked.
Mine had been put back the wrong way around and as a result the hinge was never resting on it.
NB: took the picture, uploaded it on Imgur, shared it on the forum only using my phone.
