What size wipers do you use?
- WRDendy
As per the title - mine are pretty far gone and need replacing, but I can't find a straightforward answer as to what size is recommended (or was originally supplied). Depending where I look, I see 21" both sides, 21" driver and 20" passenger, and the one I pulled off my passenger side is 19". The clips were fairly rusty and the removal process was rather destructive as far as the wiper was concerned, so changing them is now mandatory!
Has anyone done theirs recently, and if so, what did size(s) did you go for?
Formerly known as 'Jaster'
Current: '94 GT & '88 ES
Former: '89 ES
Former: '89 ES
Re: What size wipers do you use?
Hi Jaster
Here is the thing. I bought a pair of those back in May:
BOSCH Super Plus Front Pair (SPOILER) Window/Windscreen Wiper Blades 21"/21"
They fit perfectly.
They fit perfectly.
- WRDendy
Thanks, I suspected that the 21" blades would fit but worth checking nonetheless. No doubt someone fitted the 19" ones previously because that was all they happened to have at the time.
Former: '89 ES
Former: '89 ES
Yep - 21" wipers both sides.
Genuine Volvo ones were still available until very recently - don't know if they still are (they were made by Valeo, anyway).
Checked 2 of ours - 'Junk' looks like it hasn't seen a garage in many years, has 21/20, Snazzy had replacements fitted by our 480 man on her last MoT 21/21. Work perfectly so I'd go for them and have more clean screen.
I have 21' Bosch Aero twin and fit perfectly. I found in my car, when I rescued her from oblivion back in 2014,that the blades had stretched springs. I replaced them with 440 ones, much more tension on the screen,and now the Bosch wipe well all the area they're meant to cover. Worth checking out.
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
2012 Seat Exeo ST
- WRDendy
Looks like the general consensus is firmly in favor of 21" both sides then.
Do these obscure your view much? I use them on my other cars and much prefer them to standard blades, but the clip is rather large and tends to stick up into the view of the road a bit. I might pull one off the Saab (22" but close enough) and see how it looks on the 480.
Former: '89 ES
Former: '89 ES
Wish I could get new springs for my arms.
