Seat-belt buckle
frenchfries
Seat-belt buckle
Post by frenchfries » Mon Feb 05, 2018 8:36 pm
Help
I need a seat-belt clip thingy, mine is broken and this is a MOT failure, could you rummage in your lofts for me please?
WRDendy
Re: Seat-belt buckle
Post by WRDendy » Mon Feb 05, 2018 9:06 pm
I'm afraid I don't have any, but this chap claims to have three: https://www.ebay.co.uk/itm/Volvo-480-Se ... Sw~3paai4k
Formerly known as 'Jaster'
frenchfries
Post by frenchfries » Mon Feb 05, 2018 10:08 pm
I saw, £15 is too steep, made 2 offers already (I knew I would need one eventually, did not realise it would be now) but I will not be fleeced.
Post by jifflemon » Mon Feb 05, 2018 10:31 pm
You tired Curtis krozack on the fb page?
Post by brinkie » Mon Feb 05, 2018 11:06 pm
Help
I need a seat-belt buckle, mine is broken and this is a MOT failure, could you rummage in your lofts for me please?
I should have one of those somewhere, could have stuck one in the envelope together with the tweeter. But what is exactly broken? The plastic tab is missing? The buckle works perfectly without it, just grind the excess plastic away and you're sorted.
frenchfries
Post by frenchfries » Mon Feb 05, 2018 11:20 pm
Hi Brinkie
The belt itself slides into 2 openings on the buckle clip thingy, the thin plastic one on the edge is broken and the other one is cracked, not sure how clear I am in describing a buckle but it is definitely broken. By a door maybe? Not sure.
If you feel like sending one over I have your PayPal details by now :lol:
Post by brinkie » Tue Feb 06, 2018 3:15 pm
Many 480's have the same problems here and pass MOT with flying colours. The buckle is still safe if the plastic tab is broken, it's only there to slide the buckle nicely along the belt. If the plastic has sharp edges, just file it off and there should be no problem. Bu
I don't have any good ones at the moment, or I must sacrify a good rear belt just to get the buckle off. Trouble is, I can get the buckles off front seat belts without destroying them (loosen the bolt holding the bracket below with a 5/8" spanner and you can slide the loop from the belt end off), but the rear belts have been sown together, so it's a rather destructive action for the rear belt to get the buckle off.
There should be other cars with compatible belt buckles but I haven't found/tested them yet.
frenchfries
Post by frenchfries » Tue Feb 06, 2018 4:30 pm
Thanks for having a good look anyway :)
Now, the clip thingy, does it have to be the exact same model or are they swappable for one from another model of Volvo or anything?
Mine is broken, definitely broken.
Post by brinkie » Tue Feb 06, 2018 6:44 pm
I'd reckon they're the same from a 440/460 and probably those from an 850 are compatible as well. Wouldn't know if earlier (200/700/900 series) and later (S70/V70) cars have the same buckles.
balto8
Post by balto8 » Tue Feb 06, 2018 11:47 pm
400 series are all the same or quite close. I have a 440 ones in my front ones.
But I'm quite sure that 700s are pretty much the same, would either say 900s are alike from my last visit to this huge scrapyard in Alicante
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
Post by jamescarruthers » Wed Feb 07, 2018 7:53 am
I think that when manufactured, the buckle would have been put on‎ the belt, then the little "dot" that stops it sliding too far down the belt when it is retracted is added.
I've never done the job, but I'd have thought you'd have to prise the "dot" off (destroying it in the process) in order to slide a new belt on.
This sort of thing, in dark grey, can replace it: http://r.ebay.com/oCsBCe‎
I've replaced one or two of these and can advise making sure the pointy bit faces away ‎from your belly!
Lastly, does anyone know if the belt will slide over the loop at the bottom, or was that sown up after the buckle was put on the belt.
Lastly, FYI very early 480s have a slightly different design of buckle‎. So, look for post-88 Volvos in your scrap yards if you are hoping to get a match with most of your 480s.
Post by brinkie » Wed Feb 07, 2018 8:43 am
With a bit of force, I always managed to get the buckle over the dot. But they're cheap and widely available. The most tedious job was getting the belt end through the buckle.
The end of the belt is sowed into a small loop, which will slide over the metal loop. The loop is held with a 5/8" bolt, once removed you can slide the belt off easily. If you move the seat you will have more space to see what I mean. I have bought a special spanner (16 mm will fit) to remove the bolt. Never thought I'd need British tool sizes on a Swedish-Dutch car :lol:
Don't forget to remember which sides were which, otherwise you might end up with a twisted belt.
Post by Alan 480 » Wed Feb 07, 2018 1:02 pm
Brinkie
I've always assumed that the 5/8" headed bolt is to prevent DIY changes of bolt??? (7/16" UNF usually) although I have a range of said bolts in garage from various cars :-)
frenchfries
Post by frenchfries » Mon Feb 26, 2018 5:30 pm
I will sleep better at night
Seat buckle changed last week end. Turns out it was facing the wrong way, basically when the seat-belt was on it was pressing down on the thin plastic bit (the one at a 90 degree angle) thus slowly breaking it. Passenger side was the same so fixed it as well.
So that you know, the ones for sale new on Ebay for £3.09 are not working but they refund you without asking for a return.
Also fitted engine undertray (as part of my OCD) and a perfectly functioning tweeter (you know who you are).
And.........back in the garage :)
